hig cpu on WS-X6716-10GE
joestaruch
Hi all,
For several days, high CPU utilization of the module WS-X6716-10GE is reported via the LMS 4.3. This module is located in a 6509 VSS switch with . I am wondering what can be issue...
in show process cpu I do not see proces which is causing this..
thank you
Jonn cos
Level 4
Level 4
How many hosts are connected to this line card and what are they ? are you sure that they are not causing any heavy traffic (even for 10G) like some bulk database replication or something ?
Have you tried changing the slot to see if it still happens ?
Please tell the following
1) Which mode are you using ? oversubscription or performance ?
2) Which SUP ?
3) IOS ?
We are using:
Supervisor Engine 720 10GE (Active)    VS-S720-10G and following IOS:
s72033-ipservicesk9_wan-mz.122-33.SXI3
How can I identify what is cusing this problem..  what is normal cpu and what not
Thank you
It looks like modul is working in oversubscription-mode
port-group      oversubscription-mode
1               enabled
2               enabled
3               enabled
4               enabled
when I look on show cpu history there are only few peaks which reach 80%
100
90
80    *                       *                        *
70    *                       *                       **
60    *                       *    *   *   *          **       *
50 *****  ******* *** ** **** **   **  * *****       ***  ***  * ***  **
40 **********************************************************************
30 **********************************************************************
20 ###*#**********************#**#***#*********#*******#***********#****#
10 ######################################################################
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
                  * = maximum CPU%   # = average CPU% 100
