High Buffer utilization in 3750 Switch
edwinchungath
Community Member
Dears,
We are getting High Buffer utilization trigger from Cisco 3750 Switches
the threshold value is set for 60 % (in Netcool Monitoring Tool)
and the average Buffer utilization is ~40%
Intermitent spike happening with max 75 %
Do you think is it normal behavior or elve what could be the reson?
Edwin
James D Hensley
What exactly are you polling in Netcool that is reporting high buffer utilization?
How did you come up with the 60% theshold?
