high cpu and memory
kp-tkr2014
Level 3
Level 3
I have the below topology .Switch is 3560 x switches
Internet bandwidth is 100MB,
I have really doubt  the switch is  enough to handle the traffic . Switch memory and cpu is always high .
In that case which switch is suitable . Or is due to any abnormal traffic ?
In that case how can iFigure it out ?
Second thing , now the switch is managing by public ip address .
I want to manage  using private ip address
If I am using private ip address , how can I achieve maximum security
Reza Sharifi
If the switch is running with high CPU and memory, that is usually not because of 100Mb ISP connection. That switch should be able to handle 100Mb with no issues. Do a "sh process cpu sort | ex 0.00" and see what is causing the high CPU.
