high cpu on 3560G-24TS
Karel Vins
Hi all,
I have a problem with high cpu utilization - SW switching on 3560G-24TS but I can't find the reason.
There is only one access list with no log option used with PBR.
sh proc pcu
CPU utilization for five seconds: 26%/20%
TCAM is not full
Following debug shows a lot of records (here is one as sapmle)
Eg. this one is for traffic destined to localy connected machine (10.130.2.20) - why is it SW switched?
debug platform cpu-queues software-fwd-q
Feb 11 22:07:21: SW-FWD-Q:IP packet: Local Port Fwding L3If:Vlan118 L2If:GigabitEthernet0/24 DI:0x2F, LT:7, Vlan:118 S
rcGPN:24, SrcGID:24, ACLLogIdx:0x0, MacDA:0018.19cf.a5c6, MacSA: 001a.a2e8.68c0 IP_SA:10.37.32.68 IP_DA:10.130.2.20 IP
_Proto:6
TPFFD:D8000018_00000076_00B00040-0000002F_BA060000_00000000
Thanks in advance
Karel V.
Mohamad Qayoom
Level 3
Level 3
26% utilization doesn't seem very high to me.
Not sure about the other question you asked.
glen.grant
20% is not high . Do a show proc cpu sort" and it will tell you what is highest process in order .
Mayby it is not very high (in this moment, i must redirect traffic) but traffic going thru this switch has latency about 10 - 50 ms or worst in case of higher utilization.
I'm looking for reason of SW switching.
