high cpu on 6500
Muhammed AKYUZ
Hi ,
what should be the problem?
SUP2T-D#sh proce cpu hist
    11111111111     1111     1111          1111    1111
    0000000000099999000099999000099999999990000999900009999999
100 **********************************************************
90 **********************************************************
80 **********************************************************
70 **********************************************************
60 **********************************************************
50 **********************************************************
40 **********************************************************
30 **********************************************************
20 **********************************************************
10 **********************************************************
   0....5....1....1....2....2....3....3....4....4....5....5....
             0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
SUP2T-D#sh proce cpu sorted
CPU utilization for five seconds: 100%/83%; one minute: 99%; five minutes: 99%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
416     3324188    879928       3777 13.05% 14.42% 14.45%   0 Spanning Tree
633      104408      5091      20508  1.50%  0.53%  0.45%   0 Env Poll
  75       22000       298      73825  1.10%  0.13%  0.07%   0 Per-minute Jobs
168       69696    163563        426  0.39%  0.23%  0.22%   0 slcp process
   2         532      1010        526  0.07%  0.00%  0.00%   0 Load Meter
712         504      2467        204  0.07%  0.00%  0.00%   0 NF AM Main Proc
352        9224      1410       6541  0.07%  0.01%  0.00%   0 Lif stats hw rea
413       82300    238061        345  0.07%  0.03%  0.00%   0 MOP Protocols
  10       28304      1454      19466  0.07%  0.07%  0.07%   0 Check heaps
   9           0         2          0  0.00%  0.00%  0.00%   0 LC Registry Expo
  11           0         1          0  0.00%  0.00%  0.00%   0 Pool Manager
   8           0         2          0  0.00%  0.00%  0.00%   0 PF Redun ICC Req
  13           4       165         24  0.00%  0.00%  0.00%   0 WATCH_AFS
  14           0         1          0  0.00%  0.00%  0.00%   0 License Client N
  15           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
   7           0         1          0  0.00%  0.00%  0.00%   0 PF Redun ICC Req
  12           0         2          0  0.00%  0.00%  0.00%   0 Timers
SUP2T-D#show ibc
Inband counters and statistics
Interface information:
        Interface IBC0/0(idb 0x5172A510)
        5 minute  rx rate 132671000 bits/sec  215989 packets/sec
        5 minute  tx rate 5324000 bits/sec  6655 packets/sec
        841634035 Packets input, 61939066968 bytes
        674810428 broadcasts received
        31998854 Packets outputs, 3210901354 bytes
        0 broadcasts sent
        0 Inband input packet drops
        0 Inband output packet drops
        1 IBC resets
        *** Inband Generic Counters***
        841634104 Packets Input, 1809524824 Bytes
        674810466 Broadcasts Input
        31999239 Packets Output
        816543102 Total Drops
        0 software bridged paks
        0 Packets Fast switching paks
        Potential/Actual paks CEF switched 30197067/49692
        Potential/Actual paks tag CEF switched 0/0
        0 packets xconnect CEF switched
        0 Packets xconnect L2 switched
        0 packets xconnect dropped
        0 Packets immediately punted
        Potential/Actual paks copied to process level 826935947/10304396
        Potential/Actual paks copied to L2 process level 14645067/14645067
        14647635 Packets L2 processed
        2568 packets L2 switched
        0 Encapsulation corrections
        Internally intercepted packets:
         0 exc, 151275503 dindex (14647635 sp, 0 old index), 796790606 cap1, 0 cap2
        Earl8 shimmed paks rcvd:
         0 pseudoipv6 0 svchdr 30195034 shim
        *** INBAND PACKET DROPS & FAILURES ***:
          0 shim_processing 0 shim_error
          0 no idb 0 get_l2_idb failures 14644875 if_input changes
          0 intercept 88449 spd
          0 Number of times intercept function(s) returning incorrect values
          0 bridge loopback 0 diag
          0 fastsend 0 soutput 0 no mac descriptors 0 NULL if_outputs
          816543102 throttle 580 throttle sneaks
          0 encapsulation 24769 get_lif
          0 if_input corrections 0 uncorrectable if_inputs
          0 corr ecc errors
          0 null parse packet
          17360486 shim insertions attempted at tx, 24769 failed
          0 times les cef vector not set
          0 times les cef vector disabled
SUP2T-D#Show netdr captu
A total of 4096 packets have been captured
The capture buffer wrapped 0 times
Total capture capacity: 4096 packets
------- dump of incoming inband packet -------
l2idb Gi1/3, l3idb Vl10, routine inband_process_rx_packet, timestamp 00:11:47.943
dbus info: src_vlan 0xA(10), src_indx 0x2(2), len 0x51(81)
  bpdu 0, index_dir 0, flood 1, dont_lrn 0, dest_indx 0x200A(8202)
  cap1 1, cap2 0
  20820000 000A0000 00020000 51080000 06000002 8E000004 00000008 200A9360
destmac AB.00.00.02.00.00, srcmac 00.21.D8.C6.5F.80, ethertype 6002
layer 3 data: 3D000700 00000100 03030000 02000221 00030006 00000000
              00000400 023C0005 0002D805 06000200 01070006 0021D8C6
              5F806400 01799001 01019101 02EE0500 00000000 00000000
              00000000 00
l2idb Gi1/1, l3idb Vl10, routine inband_process_rx_packet, timestamp 00:11:47.943
dbus info: src_vlan 0xA(10), src_indx 0x0(0), len 0x51(81)
  cap1 1, cap2 0
  28820100 000A0000 00000000 51080000 06000052 8E000004 00000008 200AA3DA
destmac AB.00.00.02.00.00, srcmac 00.14.1B.30.50.00, ethertype 6002
              00000400 023C0005 0002D805 06000200 01070006 00141B30
              50006400 01799001 01019101 02EE0500 00000000 00000000
              00000000 00
  cap1 1, cap2 0
  30820000 000A0000 00020000 51080000 06000002 0E000004 00000008 200A69C3
              00000000 00
  cap1 1, cap2 0
  40820100 000A0000 00000000 51080000 06000002 0E000004 00000008 200A3567
              00000000 00
  cap1 1, cap2 0
  48820000 000A0000 00020000 51080000 06000012 0E000004 00000008 200AD5C0
destmac AB.00.00.02.00.00, srcmac 00.21.D8.B2.2B.00, ethertype 6002
              00000400 023C0005 0002D805 06000200 01070006 0021D8B2
              2B006400 01799001 01019101 02EE0500 00000000 00000000
              00000000 00
  cap1 1, cap2 0
  58820100 000A0000 00000000 51080000 06000012 0E000004 00000008 200A2961
              00000000 00
  cap1 1, cap2 0
  60820000 000A0000 00020000 51080000 06000052 8E000004 00000008 200A577E
              00000000 00
  cap1 1, cap2 0
  68820100 000A0000 00000000 51080000 06000012 0E000004 00000008 200AB961
              00000000 00
  cap1 1, cap2 0
  70820000 000A0000 00020000 51080000 06000002 8E000004 00000008 200AA365
              00000000 00
  cap1 1, cap2 0
  78820100 000A0000 00000000 51080000 06000052 8E000004 00000008 200A93DF
              00000000 00
  cap1 1, cap2 0
  80820000 000A0000 00020000 51080000 06000002 0E000004 00000008 200A79C9
              00000000 00
  cap1 1, cap2 0
  98820000 000A0000 00020000 51080000 06000012 0E000004 00000008 200A65CF
              00000000 00
  cap1 1, cap2 0
  A0820000 000A0000 00020000 51080000 06000012 0E000004 00000008 200ACDCF
              00000000 00
  cap1 1, cap2 0
  A8820100 000A0000 00000000 51080000 06000012 0E000004 00000008 200A796E
              00000000 00
  cap1 1, cap2 0
  B0820000 000A0000 00020000 51080000 06000052 8E000004 00000008 200AE771
              00000000 00
  cap1 1, cap2 0
  B8820100 000A0000 00000000 51080000 06000012 0E000004 00000008 200A096E
              00000000 00
  cap1 1, cap2 0
  C8820100 000A0000 00000000 51080000 06000052 8E000004 00000008 200A83D5
              00000000 00
5 Replies 5
nkarpysh
CPU is high due to interrupts (traffic) and it is good you have taken nedtr capture.
Ethertype 6002 is MOP for incoming packets
1. It looks like your router may transmit DECnet MOP (DEC Maintenance Operation Protocol (MOP)) packets (ethertype 6002) to multicast
MAC address ab00.0002.0000
2. Those packets sourced from Vlan 10(MAC 0023.33C5.AD80) were massively punted to CPU -
a part of netdrive capture below:
cap1 1, cap2 0
00000000 00
http://www.cisco.com/en/US/tech/tk870/tk136/tk885/technologies_tech_note09186a0080093cd1.s
html
3.You can jcheck if  MOP protocol and MOP sysid enabled on on Vlan4005 or inout interfaces Gi1/1 and Gi1/3 and consider if you want to remove.
4. You can also trace the source MAcs of coming packets and understand why MOP traffic is coming from it.
Hope this helps,
Nik
HTH,
Niko
thank you for your answer.
I have disable mop on vlan interfaces, but still same.
how can i completely disabe mop?
Hey.
Did you check it on physical interfaces as well? It might be needed to be disabled there. Also you can see where those source MAcs 00.21.D8.B2.2B.00 and 00.14.1B.30.50.00 are coming from. I do see these two sending MOP packets.
check where those are learnt from with "show mac-addr addr 0014.1B30.5000" or similar (based on platform) command and go to the device connected on that interface to do same check until you find the end host with that MAC.
Hope that helps.
Nik
HTH,
Niko
hi,
i have diasble mop on physical interfaces also.  g1/1 ang g1/3 are also 6500. I have disable mop on their phsical and vlan interfaces but netdr output still shows ether 6002..  can i police these packets via COPP?
I guess CoPP wont help here as ethertype 6002 is not ip so IP acl wont help and Copp afaik does not support MAC acl.
You can try to create MAC ACL or VACL and apply that on port just to drop those MAC addresses as sources.
I guess now even with MOP disabled switch treat destination MAC of those packets like some mcast MAC and send copy ofr CPU analysis.
Nik
HTH,
Niko
