High cpu on MSFC2
k.ramalingam
Experts,
I have issue with high cpu on the msfc2. This MSFC is on the 2nd core switch with all its hsrp status standby. THe process that is eating up the process is SCP async: MLS_E
Any suggestion would be great
drolemc
Level 6
Level 6
The MSFC shows high CPU utilization and the process is SCP async. SCP is the out of band protocol used for communication among Sup module and the rest of the cards in the chassis including the MSFC daughter card.
Therefore, the action plan would be to check that modules are properly seated in the chassis; check and reset them if required.
And check for any pin or notable damage.
