High CPU Usage on C4507
Dian Rubens
Hi community.
A 4507 switch has high CPU issues, if we introduce the command show processes cpu, the outputs says that a process called Cat4k Mgmt LoPri consumes aprox 80 to 90%:
4507#show processes cpu
CPU utilization for five seconds: 94%/4%; one minute: 95%; five minutes: 97%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
 69           0           3          0  0.00%  0.00%  0.00%   0 ARP HA
  70           0           2          0  0.00%  0.00%  0.00%   0 SISF HA Process
  71           0           4          0  0.00%  0.00%  0.00%   0 MSP HA
  72           0           2          0  0.00%  0.00%  0.00%   0 MSP HA IPC flow
  73           0           1          0  0.00%  0.00%  0.00%   0 DHCPC HA
  74           0           1          0  0.00%  0.00%  0.00%   0 DHCPD HA
  75           0           1          0  0.00%  0.00%  0.00%   0 Network-rf Notif
  76    61748992   169810858        363  4.31%  4.32%  4.31%   0 Cat4k Mgmt HiPri
  77   350784471   392501329        893 78.07% 79.72% 81.35%   0 Cat4k Mgmt LoPri
  78         880      395330          2  0.00%  0.00%  0.00%   0 Galios Reschedul
  79           0           1          0  0.00%  0.00%  0.00%   0 IOS SGACL Helper
  80         596         537       1109  0.00%  0.00%  0.00%   0 GaliosObflLogger
  81           0           4          0  0.00%  0.00%  0.00%   0 IOS ACL Helper
  82           0           1          0  0.00%  0.00%  0.00%   0 GalRedMsgProc
  83           8          16        500  0.00%  0.00%  0.00%   0 RF Master Main T
  84           0          11          0  0.00%  0.00%  0.00%   0 RF Master Status
Following the guide for High CPU utilization Catalyst 4500 switches (https://www.cisco.com/c/en/us/support/docs/switches/catalyst-4000-series-switches/65591-cat4500-high-cpu.html), we introduce the command show platform health with the item named K5CpuMan Review consuming an 88% of CPU.
4507#show platform health
                     %CPU   %CPU    RunTimeMax   Priority  Average %CPU  Total
                     Target Actual Target Actual   Fg   Bg 5Sec Min Hour  CPU
RkiosObflMan           0.50   0.00      4      0  100  500    0   0    0  0:31
VSI slot-03            1.00   0.05      6      0  100  500    0   0    0  9:28
K5 L2 Hardware Addre   2.00   0.00     20     10  100  500    0   0    0  2549:05
K5 L2 Hardware Mac L   1.00   0.00      2      0  100  500    0   0    0  0:00
K5RetStatsMan Review   2.00   0.00      5      0  100  500    0   0    0  0:00
K5CpuMan Review       30.00  88.37     30     21  100  500  166 167  124  5353:16
K5ForerunnerPacketMa   2.00   4.81      4      0  100  500    5   5    4  367:29
K5ForerunnerPacketMa   2.00   0.28      4      0  100  500    0   0    0  28:26
Introducing the command show platform cpu packet statistics we saw that the switch is dropping massive packets on l2 router (the complete output below):
4507#show platform cpu packet statistics
RkGenericPacketMan:
Packet allocation failures: 0
Packet Buffer(SW Common) allocation failures: 0
Packet Buffer(SW ESMP) allocation failures: 0
Packet Buffer(SW EOBC) allocation failures: 0
Packet Buffer(SW SupToSup) allocation failures: 0
Packets Dropped In Processing Overall
Total                5 sec avg 1 min avg 5 min avg 1 hour avg
            84346886        42        23        23         25
Packets Dropped In Processing by CPU event
Event             Total                5 sec avg 1 min avg 5 min avg 1 hour avg
Sa Miss                       65560165         0         0         0          0
L2 Router                     18773630        42        23        22         24
Input Acl Fwd                       58         0         0         0          0
Input ACl Copy                   11226         0         0         0          0
Output Acl Copy                   1807         0         0         0          0
Packets Dropped In Processing by Priority
Priority          Total                5 sec avg 1 min avg 5 min avg 1 hour avg
Normal                        18781484        42        23        22         24
Medium                        65560165         0         0         0          0
High                              5237         0         0         0          0
Packets Dropped In Processing by Reason
Reason             Total                5 sec avg 1 min avg 5 min avg 1 hour avg
STPDrop                             473         0         0         0          0
AclActionDrop                      1802         0         0         0          0
NoDstPorts                            5         0         0         0          0
Tx Mode Drop                   65570976         0         0         0          0
Extra packet due to RxProc hwAssisted Bridging             18773630        42        23        22         24
Total packet queues 64
Packets Received by Packet Queue
Queue                  Total           5 sec avg 1 min avg 5 min avg 1 hour avg
Esmp                          17334707        28        20        17          9
Input ACL fwd(snooping)       288909409       260       242       195        187
Host Learning                 65554306         0         0         0          0
L2 Control                     9084507        15         8        10          1
Input ACL log, unreach           11226         0         0         0          0
Ttl Expired                        119         0         0         0          0
Output ACL log, unreach            1807         0         0         0          0
Adj SameIf Fail                 457675         6         0         0          0
Bfd                                 73         0         0         0          0
L2 router to CPU, 7         6264331074      6337     19380     17625      15668
L3 Glean, 7                    1309226         5         0         0          0
L3 Fwd, 7                           80         0         0         0          0
L3 Receive, 7                  1604009         7         2         2          1
Packets Dropped by Packet Queue
Esmp                               386         0         0         0          0
Host Learning                     1040         0         0         0          0
Adj SameIf Fail                    895         0         0         0          0
L2 router to CPU, 7           59168345        33        97        29          7
Anyone knows what is the association of the last line? What can be causing the overprocesing of the CPU?
Thanks.
Damien Miller
Dian,
Are you running VSS? The "SA Miss" is very high which leads me to believe one of the two bugs I linked below. You didn't mention the sup or ios you're running but I find these aren't always accurate on the public facing reports anyways. Are you running and SPAN sessions on the chassis? sh monitor session will spit that out. I would suggest a TAC case if you have an active agreement.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtb44674
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuh50329
Leo Laohoo
Post the complete output to the following commands:
1. sh proc cpu sort | ex 0.00
2. sh version
