High CPU usage
abarb002
Level 4
Level 4
CPU 1 is functioning at 85% workload. I've researched different ways to lower this, like CEF and MLS all which are being used currently on this layer 3 switch. Also looked into changing my log statements in my ACLs to address the IP input (biggest user under cpu processes) but I can't do that because its required by STIG rules. I just started using Solarwinds to monitor my network so I don't know how long this high usage rate has been going.
Question, is this normal for a 6506 with one 720 SUP? Is there something that can be done to load balance traffic? We are currently in the middle of an operation so I can't shut nor restart any network devices. Any suggestions are greatly appreciated.
abarb002
Level 4
Level 4
At some point during the past few days there was a spike that caused the CPU to reach a load usage of 85%. I removed the switch from Solarwinds and rediscovered it and the CPU load warning went away. I doubled checked the cpu, #sh proc cpu, and everything was normal.  However the cpu history did show spikes. I will keep monitoring this and update if this occurs again.
Reza Sharifi
That is not normal. The high CPU is most likely because of a bug in the software version you are running. I suggest you open a ticket with Cisco and have them investigate  a possible resolution.
abarb002
Level 4
Level 4
SNMP discovery issues like this is usually because of a bug in the switch IOS.
I have seen this in Nexus series, where SNMP causes a serious slowness in show commands. You may also want to post this on the SW forum, just in case this is an NPM related issue.
