High CPU utilization after enabling ipv6
yakimus.voks
Hi everyone!
Got an issue on two cisco's C3560G with different versions of IOS. When enable ipv6 and reboot, the CPU usage rises up to 92-100%
One has flash:c3560-ipservicesk9-mz.122-50.SE3.bin the other has flash:/c3560-ipservices-mz.122-37.SE1.bin
Both are used as iBGP routers on ipv4 and both had CPU util at level of 6-8% before enabling ipv6. Overall traffic does not exceed a mark of 400M per port.
Should I disable ipv6 and reboot -- the CPU util becomes normal.
I wonder if it is a common issue and I cannot use C3560G as iBGP router in both ipv4 and ipv6 or is there a solution?
yakimus.voks
so, i guess no answer for my issue? Only I tried to have ipv6 working at C3560G?
