High CPU utilization (HL3U bkgrd proc)
CSCO11584685
So, im running a policy based routing on cisco 3560. the cpu utilization is pretty high.
attached the output for
show proc cpu sort
show proc cpu hist
show sdm prefer
show platform tcam utilization
6 Replies 6
vragotha
Level 3
Level 3
Attach a 'show version' always
there you go.
WebCache#show version
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(53)SE, R
ELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Sun 13-Dec-09 15:45 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02E00000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(50r)SE, RELEASE SOFTWARE
(fc1)
WebCache uptime is 1 day, 30 minutes
System image file is "flash:/c3560-ipservicesk9-mz.122-53.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3560V2-24PS (PowerPC405) processor (revision D0) with 131072K bytes of
memory.
Processor board ID FDO1402Y1H7
Last reset from power-on
2 Virtual Ethernet interfaces
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 04:FE:7F:F0:90:80
Motherboard assembly number     : 73-11706-10
Power supply part number        : 341-0266-02
Motherboard serial number       : FDO14021GJQ
Power supply serial number      : LIT134702TC
Model revision number           : D0
Motherboard revision number     : A0
Model number                    : WS-C3560V2-24PS-S
System serial number            : FDO1402Y1H7
Top Assembly Part Number        : 800-31038-02
Top Assembly Revision Number    : A0
Version ID                      : V02
CLEI Code Number                : COMNK10CRA
Hardware Board Revision Number  : 0x03
Switch Ports Model              SW Version            SW Image
*    1 26    WS-C3560V2-24PS    12.2(53)SE            C3560-IPSERVICESK9-M
Configuration register is 0xF
WebCache#
Hello Sulaiman,
post the configuration of the PBR rule to see if there is a chance that traffic is not processed in hardware
Resource usage is not too much.
See PBR guidelines
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_52_se/configuration/guide/swiprout.html#wp1210866
Hope to help
Giuseppe
here are the configurations
interface Vlan300
ip address xx.xx.xx.xx 255.255.255.0
ip policy route-map web
ip access-list extended web
permit tcp xx.xx.xx.xx 0.0.15.255 any eq www
permit tcp xx.xx.xx.xx 0.0.15.255 any eq 443
route-map web permit 10
match ip address web
set ip next-hop yy.yy.yy.yy
route-map web permit 20
the routing is working fine, there is no packet drop of any kind. and the router is working as intended. the only issue is, the high utilization.
EDIT.
going through that document i found two things. first
1-
When configuring match criteria in a route map, follow these guidelines:
Do not match ACLs with deny ACEs. Packets that match a deny ACE are sent to the CPU, which could cause high CPU utilization.(any acl will have a deny any any statement at the end, is that causing this issue?)
2- i have not enabled fast-swtiching PBR
ip route-cache policy
(Optional) Enable fast-switching PBR. You must first enable PBR before enabling fast-switching PBR.
CSCO11584685
any input guys. !
Hello Sulaiman,
the suggested command is a good tool for software based routers, but your C3560 should be able to perform PBR with appropriate programming of the TCAM table.
the PBR rule does not appear to use statements that could cause process switching
Further actions can be:
a bug search for the name of the process
a search in troubleshooting notes for C3560
an attempt to use an older IOS image to see if behaviour changes
Edit:
the high cpu troubheshooting for C3750/C3560 :
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/troubleshooting/cpu_util.html
try to follow suggested steps to identify the causes of high cpu usage in your switch
Hope to help
Giuseppe
