High CPU Utilization on CISCO 3845
luanlvt02
We have a Cisco 3845 router configured as a voice gateway with multi SIP trunks. But when it reachs 200 calls traffic, the CPU increase to 60-70% and caused by CCSIP_SPI_CONTROL process.
CPU utilization for five seconds: 46%/30%; one minute: 54%; five minutes: 58%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
377   400729448   171017979       2343  6.31% 10.71% 12.44%   0 CCSIP_SPI_CONTRO
365    89239288   197275072        452  2.55%  2.61%  2.72%   0 VOIP_RTCP
147    93017972   269045929        345  2.55%  2.51%  2.58%   0 IP Input
  65   107469652     8634364      12446  1.19%  1.16%  1.17%   0 Per-Second Jobs
379    78432948   156592321        500  1.11%  1.94%  2.20%   0 CCSIP_UDP_SOCKET
According to the document from CISCO, this issue should be originated from DTMF is not RFC2833 and command "sip-kpml" in dial-peer instead of
dtmf-relay rtp-nte. But in our configuration, we use DTMF with RFC2833 for sure and dtmf-relay rtp-nte for all dial-peers and I don't think it's the main reason making high CPU.
Can you give me any suggesstion for this case? The IOS is : c3845-adventerprisek9-mz.151-3.T3.bin
Also, this is proccess memmory in our gw :
sh proc mem sor
Processor Pool Total:  343584124 Used:  151203668 Free:  192380456
      I/O Pool Total:   40893952 Used:   14894528 Free:   25999424
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0  103592788   45980208   44616904          0          0 *Init*
   0   0 4216211956 2975264304   38130476    2622976      31460 *Dead*
   1   0 2639240936 2625300112   26660328          0          0 Chunk Manager
377   0 1694209216  953055252   24561348          0          0 CCSIP_SPI_CONTRO
363   0 1654981196 1570893068   11654856       6804          0 CC-API_VCM
   0   0          0          0    6472468          0          0 *MallocLite*
Renan Abreu
Do you have another log showing the high CPU? this one is not that bad and it is pointing to high CPU due to interrupts (30% does not sound bad for 200 calls at the same time), not for process, take a look at the link below.
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00800a70f2.shtml#high_cpu
Is it still happening?
