09-05-2016 02:41 AM - edited 03-08-2019 07:18 AM
Please find the below output and suggest me the solution; continouesly we are monitoring and still it is same.
show processes cpu | ex 0.0
Core 0: CPU utilization for five seconds: 9%; one minute: 39%; five minutes: 44%
Core 1: CPU utilization for five seconds: 8%; one minute: 25%; five minutes: 28%
Core 2: CPU utilization for five seconds: 98%; one minute: 90%; five minutes: 71%
Core 3: CPU utilization for five seconds: 94%; one minute: 56%; five minutes: 68%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
5625 1453224 977137174 1485 49.6 49.7 49.7 1088 fed
5626 1150681 266459027 13 0.19 0.12 0.11 0 platform_mgr
6290 1696269 81163310 1185 0.15 0.15 0.15 0 cpumemd
9209 2001482 351735189 208 2.24 2.30 2.22 0 iosd
show version
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.02.02.SE RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Fri 14-Jun-13 19:24 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 1.2, RELEASE SOFTWARE (P)
TAS-IDirect-SW03 uptime is 26 weeks, 4 days, 2 hours, 45 minutes
Uptime for this control processor is 26 weeks, 4 days, 2 hours, 47 minutes
System returned to ROM by reload
System image file is "flash:packages.conf"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: Ipbase
License Type: Permanent
Next reload license Level: Ipbase
cisco WS-C3850-24P (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FOC1735U0N3
2 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
1609272K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of at webui:.
Base Ethernet MAC Address : e8:ed:f3:9a:da:00
Motherboard Assembly Number : 73-14441-06
Motherboard Serial Number : FOC17343EL3
Model Revision Number : F0
Motherboard Revision Number : B0
Model Number : WS-C3850-24P
09-05-2016 04:28 AM
that's not a good release known 03.02.02 to have a lot of issues I would move to the safe harbour it should fix it 3.6.5MD
https://software.cisco.com/download/release.html?mdfid=284455435&flowid=37773&softwareid=282046477&release=3.6.5E&relind=AVAILABLE&rellifecycle=MD&reltype=latest
