cisco 3750x stack power between two stacks
sergeymolchanov
Hello.
I want to deploy a shared Stack Power between two independent Cisco 3750x swith stacks (see the topology in attachment)
Is this topology correct? Or Stack Power may be implemented only for each stack separately?
Mark Malone
that's not recommended by Cisco so I would avoid doing it if possible
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-x-series-switches/white_paper_c11-578931.html
"The power stack reports all of the Cisco StackPower information to the stack master; therefore, configuring a power stack that spans multiple data stacks is not recommended (see the “Best Practices” section)."
Mark Malone
