High CPU utilization problem,pls help!!
timber2005
hi,all
   i got some problems,I found the "dhcpd receive" process consume too much CPU, how can i fix it?
   attached file is "show process cpu" command output. (running on WS-4507R with cat4500-entservicesk9-mz.150-2.SG1.bin)
#sh platform cpu packet statistics all
Packets Dropped In Hardware By CPU Subport (txQueueNotAvail)
CPU Subport  TxQueue 0       TxQueue 1       TxQueue 2       TxQueue 3
           0               0            7398               0       922470635
           1               0               0               0               0
           2               0            1748               0               0
           3               0               0               0               0
           4               0               0               0               0
           5               0               0               0               0
           6               0               0               0               0
           7               0               0               0               0
RkiosSysPacketMan:
Packet allocation failures: 0
Packet Buffer(Software Common) allocation failures: 0
Packet Buffer(Software ESMP) allocation failures: 0
Packet Buffer(Software EOBC) allocation failures: 0
Packet Buffer(Software SupToSup) allocation failures: 0
IOS Packet Buffer Wrapper allocation failures: 0
Packets Enqueued Overall
Total                5 sec avg 1 min avg 5 min avg 1 hour avg
                   0         0         0         0          0
Packets Not Enqueued Overall
                   0         0         0         0          0
Packets Dropped In Processing Overall
             7938572         0         0         0          0
Packets Not Enqueued by CPU event
Event             Total                5 sec avg 1 min avg 5 min avg 1 hour avg
Control Packet                       0         0         0         0          0
Input Acl                            0         0         0         0          0
RPF Fail                             0         0         0         0          0
Adjacency Same If                    0         0         0         0          0
L3 Forward                           0         0         0         0          0
NFL Copy To CPU                      0         0         0         0          0
Output Acl                           0         0         0         0          0
MTU Check Fail                       0         0         0         0          0
SA Miss                              0         0         0         0          0
L2 Forward                           0         0         0         0          0
SPAN                                 0         0         0         0          0
CPU Generated                        0         0         0         0          0
Unknown                              0         0         0         0          0
Packets Dropped In Processing by CPU event
Input Acl                      7932929         0         0         0          0
RPF Fail                             0         0         0         0          0
Output Acl                          90         0         0         0          0
SA Miss                           5538         0         0         0          0
SPAN                                 0         0         0         0          0
Unknown                              0         0         0         0          0
RPF Fail                             0         0         0         0          0
SPAN                                 0         0         0         0          0
Unknown                              0         0         0         0          0
Packets Not Enqueued by Priority
Priority          Total                5 sec avg 1 min avg 5 min avg 1 hour avg
Unknown                              0         0         0         0          0
Normal                               0         0         0         0          0
Medium                               0         0         0         0          0
High                                 0         0         0         0          0
Crucial                              0         0         0         0          0
Super Crucial                        0         0         0         0          0
Packets Dropped In Processing by Priority
Unknown                              0         0         0         0          0
Normal                             415         0         0         0          0
Medium                            5553         0         0         0          0
High                           7932619         0         0         0          0
Crucial                              0         0         0         0          0
Packets Not Enqueued by Reason
Reason            Total                5 sec avg 1 min avg 5 min avg 1 hour avg
RxQueueNotAvail                      0         0         0         0          0
RxNoBuffersAvail                     0         0         0         0          0
RxBadCpuEvent                        0         0         0         0          0
Testing                              0         0         0         0          0
Packets Dropped In Processing by Reason
BadPddType                            0         0         0         0          0
VlanZeroBadCrc                        0         0         0         0          0
VlanZeroGoodCrc                       0         0         0         0          0
ReplVlan0GoodCrc                      0         0         0         0          0
NoPimPhyportMap                       0         0         0         0          0
NoPimPhyport                          0         0         0         0          0
UnimplementedEvt                      0         0         0         0          0
SrcAddrTableFilt                   1557         0         0         0          0
NoL2Vlan                              0         0         0         0          0
STPDrop                            3981         0         0         0          0
UnknownLyr-Bridge                     0         0         0         0          0
UnknownLyr-OutAcl                    90         0         0         0          0
L2DstDrop                            12         0         0         0          0
L2DstDropInAcl                        0         0         0         0          0
L2DstDropOutAcl                       0         0         0         0          0
AclNoVlan                             0         0         0         0          0
AclActionDrop                         0         0         0         0          0
AclActionRedirect                     0         0         0         0          0
AclActionUnsupptd                     0         0         0         0          0
UnknownBridgeAct                      0         0         0         0          0
NoTxInfo                              0         0         0         0          0
NoDstPorts                      7932932         0         0         0          0
NoFloodPorts                          0         0         0         0          0
ControlNoL2DstEnt                     0         0         0         0          0
InvalidAclAction                      0         0         0         0          0
AclInputErr                           0         0         0         0          0
OutAclEvntOnInAcl                     0         0         0         0          0
AclOutputErr                          0         0         0         0          0
ReservedPort                          0         0         0         0          0
EsmpNoTxInfo                          0         0         0         0          0
UnknownSource                         0         0         0         0          0
NoDriverTxPackets                     0         0         0         0          0
NoPimPort                             0         0         0         0          0
RouteLookupFailed                     0         0         0         0          0
FragPktAllocFailed                    0         0         0         0          0
IpHdrException                        0         0         0         0          0
SpanEvent                             0         0         0         0          0
Dot1xUnauthCtrlPkt                    0         0         0         0          0
No Sw port for ARP                    0         0         0         0          0
No Sw port for ESMP                    0         0         0         0          0
CtrlPktInBadEtherType                    0         0         0         0          0
PortMacOperationallyDown                    0         0         0         0          0
Total packet queues 16
Packets Received by Packet Queue
Queue                  Total           5 sec avg 1 min avg 5 min avg 1 hour avg
Esmp                        2830872005       125       110        79         71
L2/L3Control                 752444885        31        22        20         20
Host Learning                 94862324         3         0         1          1
L3 Fwd High                        439         0         0         0          0
L3 Fwd Medium                    68226         0         0         0          0
L3 Fwd Low                   105911724         5         0         1          1
L2 Fwd High                          0         0         0         0          0
L2 Fwd Medium                     9144         0         0         0          0
L2 Fwd Low                  1033665357       253       232       165         76
L3 Rx High                     1163622         0         0         0          0
L3 Rx Low                   2379160134       243       263       194         99
RPF Failure                          0         0         0         0          0
ACL fwd(snooping)                    0         0         0         0          0
ACL log, unreach                 33482         0         0         0          0
ACL sw processing            108494909         9         4         5          4
MTU Fail/Invalid                     0         0         0         0          0
Packets Dropped by Packet Queue
Esmp                                 0         0         0         0          0
L2/L3Control                         0         0         0         0          0
Host Learning                       79         0         0         0          0
L3 Fwd High                          0         0         0         0          0
L3 Fwd Medium                        0         0         0         0          0
L3 Fwd Low                           0         0         0         0          0
L2 Fwd Medium                        0         0         0         0          0
L2 Fwd Low                           0         0         0         0          0
L3 Rx High                           0         0         0         0          0
L3 Rx Low                            2         0         0         0          0
ACL log, unreach                     0         0         0         0          0
ACL sw processing                    0         0         0         0          0
Packets Transmitted from CPU per Output Interface
Interface              Total           5 sec avg 1 min avg 5 min avg 1 hour avg
Fa3/1                                0         0         0         0          0
Fa3/2                                0         0         0         0          0
Fa3/3                                0         0         0         0          0
Fa3/4                                0         0         0         0          0
Fa3/5                                0         0         0         0          0
Fa3/6                                0         0         0         0          0
Fa3/7                                0         0         0         0          0
Fa3/8                                0         0         0         0          0
Fa3/9                                0         0         0         0          0
Fa3/10                               0         0         0         0          0
Fa3/11                               0         0         0         0          0
Fa3/12                               0         0         0         0          0
Fa3/13                               0         0         0         0          0
Fa3/14                               0         0         0         0          0
Fa3/15                               0         0         0         0          0
Fa3/16                               0         0         0         0          0
Fa3/17                               0         0         0         0          0
Fa3/18                               0         0         0         0          0
Fa3/19                               0         0         0         0          0
Fa3/20                               0         0         0         0          0
Fa3/21                               0         0         0         0          0
Fa3/22                               0         0         0         0          0
Fa3/23                               0         0         0         0          0
Fa3/24                               0         0         0         0          0
Fa3/25                               0         0         0         0          0
Fa3/26                               0         0         0         0          0
Fa3/27                               0         0         0         0          0
Fa3/28                               0         0         0         0          0
Fa3/29                               0         0         0         0          0
Fa3/30                               0         0         0         0          0
Fa3/31                               0         0         0         0          0
Fa3/32                               0         0         0         0          0
Fa3/33                               0         0         0         0          0
Fa3/34                               0         0         0         0          0
Fa3/35                               0         0         0         0          0
Fa3/36                               0         0         0         0          0
Fa3/37                               0         0         0         0          0
Fa3/38                               0         0         0         0          0
Fa3/39                               0         0         0         0          0
Fa3/40                               0         0         0         0          0
Fa3/41                               0         0         0         0          0
Fa3/42                               0         0         0         0          0
Fa3/43                               0         0         0         0          0
Fa3/44                               0         0         0         0          0
Fa3/45                               0         0         0         0          0
Fa3/46                               0         0         0         0          0
Fa3/47                               0         0         0         0          0
Fa3/48                               0         0         0         0          0
Fa4/1                                0         0         0         0          0
Fa4/2                                0         0         0         0          0
Fa4/3                                0         0         0         0          0
Fa4/4                                0         0         0         0          0
Fa4/5                                0         0         0         0          0
Fa4/6                                0         0         0         0          0
Fa4/7                                0         0         0         0          0
Fa4/8                                0         0         0         0          0
Fa4/9                                0         0         0         0          0
Fa4/10                               0         0         0         0          0
Fa4/11                               0         0         0         0          0
Fa4/12                               0         0         0         0          0
Fa4/13                               0         0         0         0          0
Fa4/14                               0         0         0         0          0
Fa4/15                               0         0         0         0          0
Fa4/16                               0         0         0         0          0
Fa4/17                               0         0         0         0          0
Fa4/18                               0         0         0         0          0
Fa4/19                               0         0         0         0          0
Fa4/20                               0         0         0         0          0
Fa4/21                               0         0         0         0          0
Fa4/22                               0         0         0         0          0
Fa4/23                               0         0         0         0          0
Fa4/24                               0         0         0         0          0
Fa4/25                               0         0         0         0          0
Fa4/26                               0         0         0         0          0
Fa4/27                               0         0         0         0          0
Fa4/28                               0         0         0         0          0
Fa4/29                               0         0         0         0          0
Fa4/30                               0         0         0         0          0
Fa4/31                               0         0         0         0          0
Fa4/32                               0         0         0         0          0
Fa4/33                               0         0         0         0          0
Fa4/34                               0         0         0         0          0
Fa4/35                               0         0         0         0          0
Fa4/36                               0         0         0         0          0
Fa4/37                               0         0         0         0          0
Fa4/38                               0         0         0         0          0
Fa4/39                               0         0         0         0          0
Fa4/40                               0         0         0         0          0
Fa4/41                               0         0         0         0          0
Fa4/42                               0         0         0         0          0
Fa4/43                               0         0         0         0          0
Fa4/44                               0         0         0         0          0
Fa4/45                               0         0         0         0          0
Fa4/46                               0         0         0         0          0
Fa4/47                               0         0         0         0          0
Fa4/48                               0         0         0         0          0
Gi5/1                                0         0         0         0          0
Gi5/2                                0         0         0         0          0
Gi5/3                                0         0         0         0          0
Gi5/4                                0         0         0         0          0
Gi5/5                                0         0         0         0          0
Gi5/6                                0         0         0         0          0
Gi1/1                                0         0         0         0          0
Gi1/2                                0         0         0         0          0
Packets Received at CPU per Input Interface
Fa3/1                                0         0         0         0          0
Fa3/2                                0         0         0         0          0
Fa3/3                                0         0         0         0          0
Fa3/4                                0         0         0         0          0
Fa3/5                                0         0         0         0          0
Fa3/6                                0         0         0         0          0
Fa3/7                                0         0         0         0          0
Fa3/8                                0         0         0         0          0
Fa3/9                                0         0         0         0          0
Fa3/10                               0         0         0         0          0
Fa3/11                               0         0         0         0          0
Fa3/12                               0         0         0         0          0
Fa3/13                               0         0         0         0          0
Fa3/14                               0         0         0         0          0
Fa3/15                               0         0         0         0          0
Fa3/16                               0         0         0         0          0
Fa3/17                               0         0         0         0          0
Fa3/18                               0         0         0         0          0
Fa3/19                               0         0         0         0          0
Fa3/20                               0         0         0         0          0
Fa3/21                               0         0         0         0          0
Fa3/22                               0         0         0         0          0
Fa3/23                               0         0         0         0          0
Fa3/24                               0         0         0         0          0
Fa3/25                               0         0         0         0          0
Fa3/26                               0         0         0         0          0
Fa3/27                               0         0         0         0          0
Fa3/28                               0         0         0         0          0
Fa3/29                               0         0         0         0          0
Fa3/30                               0         0         0         0          0
Fa3/31                               0         0         0         0          0
Fa3/32                               0         0         0         0          0
Fa3/33                               0         0         0         0          0
Fa3/34                               0         0         0         0          0
Fa3/35                               0         0         0         0          0
Fa3/36                               0         0         0         0          0
Fa3/37                               0         0         0         0          0
Fa3/38                               0         0         0         0          0
Fa3/39                               0         0         0         0          0
Fa3/40                               0         0         0         0          0
Fa3/41                               0         0         0         0          0
Fa3/42                               0         0         0         0          0
Fa3/43                               0         0         0         0          0
Fa3/44                               0         0         0         0          0
Fa3/45                               0         0         0         0          0
Fa3/46                               0         0         0         0          0
Fa3/47                               0         0         0         0          0
Fa3/48                               0         0         0         0          0
Fa4/1                                0         0         0         0          0
Fa4/2                                0         0         0         0          0
Fa4/3                                0         0         0         0          0
Fa4/4                                0         0         0         0          0
Fa4/5                                0         0         0         0          0
Fa4/6                                0         0         0         0          0
Fa4/7                                0         0         0         0          0
Fa4/8                                0         0         0         0          0
Fa4/9                                0         0         0         0          0
Fa4/10                               0         0         0         0          0
Fa4/11                               0         0         0         0          0
Fa4/12                               0         0         0         0          0
Fa4/13                               0         0         0         0          0
Fa4/14                               0         0         0         0          0
Fa4/15                               0         0         0         0          0
Fa4/16                               0         0         0         0          0
Fa4/17                               0         0         0         0          0
Fa4/18                               0         0         0         0          0
Fa4/19                               0         0         0         0          0
Fa4/20                               0         0         0         0          0
Fa4/21                               0         0         0         0          0
Fa4/22                               0         0         0         0          0
Fa4/23                               0         0         0         0          0
Fa4/24                               0         0         0         0          0
Fa4/25                               0         0         0         0          0
Fa4/26                               0         0         0         0          0
Fa4/27                               0         0         0         0          0
Fa4/28                               0         0         0         0          0
Fa4/29                               0         0         0         0          0
Fa4/30                               0         0         0         0          0
Fa4/31                               0         0         0         0          0
Fa4/32                               0         0         0         0          0
Fa4/33                               0         0         0         0          0
Fa4/34                               0         0         0         0          0
Fa4/35                               0         0         0         0          0
Fa4/36                               0         0         0         0          0
Fa4/37                               0         0         0         0          0
Fa4/38                               0         0         0         0          0
Fa4/39                               0         0         0         0          0
Fa4/40                               0         0         0         0          0
Fa4/41                               0         0         0         0          0
Fa4/42                               0         0         0         0          0
Fa4/43                               0         0         0         0          0
Fa4/44                               0         0         0         0          0
Fa4/45                               0         0         0         0          0
Fa4/46                               0         0         0         0          0
Fa4/47                               0         0         0         0          0
Fa4/48                               0         0         0         0          0
Gi5/1                                0         0         0         0          0
Gi5/2                                0         0         0         0          0
Gi5/3                                0         0         0         0          0
Gi5/4                                0         0         0         0          0
Gi5/5                                0         0         0         0          0
Gi5/6                                0         0         0         0          0
Gi1/1                                0         0         0         0          0
Gi1/2                                0         0         0         0          0
0 Replies 0
