HIGH CPU Utilization
ajit_bict
Community Member
Hello, We at SSIPL Retail Ltd are using 3750-48-TS in stack as a core switch. Since last few days the CP utilization has become high up to 80%
Please provide the resolution.
Ajit Kumar
9810689675
[email protected]
Peter Paluch
Hi Ajit,
Identifying the root cause of a high CPU load is a difficult process, and requires knowing significant amounts of details about your configuration and perhaps even traffic types and patterns. You have not provided any of these details so we can only give you general guidance.
There are two documents published on the Cisco website that specifically focus on troubleshooting the high CPU issues on 3750 in particular. These are the links - I recommend reading them very carefully, and trying to narrow down the possible cause of your high CPU based on the information in these two documents.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/troubleshooting/cpu_util.html
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/68461-high-cpu-utilization-cat3750.html
Best regards,
Peter
