high cpu utilization
nitass
Dear all
For the normail time, The cpu utilization of L3 Switch (4507R Version 12.2(20)EWA) about 30%-40%.
For now, It about 60%-70%.
I didn't change any configuration of the switch.
I attached a file that contain the output of "show tech-support".
Please advice me how to solve this issue.
Thank you
Pornthip
vijayasankar
Level 4
Level 4
A Quick at your cpu stats shows that "Virtual Exec" task is taking more cpu cycles.
Probably if you have captured the show tech-support output via a telnet session, that could contribute to the cause for this and if so we can ignore this process.
I could also see the following processes eating up a lot of cpu cycle.
Cat4k Mgmt HiPri and Cat4k Mgmt LoPri .
These two processes aggregate multiple platform-specific processes which perform the essential management functions on the Catalyst 4500. These processes process control plane as well as data packets that need to be software-switched or processed.
Have a look at this URL, which will help you troubleshoot the root cause of this.
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml
Follow the steps as outlined in the above URL to diagnose where the problem is.
-VJ
