high cpu with cisco 7600 and dont know why ???!!!
Dr.X
Level 2
Level 2
hi , i have cisco 7600 router ,
here is show run :
Gateway7600#sh run
Building configuration...
Current configuration : 4787 bytes
! Last configuration change at 09:08:04 UTC Sat Apr 20 2013 by xxxx
version 15.2
service password-encryption
service counters max age 10
hostname Gateway7600
boot-start-marker
boot-end-marker
no logging buffered
enable secret 4 hELPh0MycCJUBD0yxSm5sU05Ew4KLvVXPCEVqVOWpb6
no aaa new-model
no ip domain lookup
ipv6 multicast rpf use-bgp
vtp mode transparent
mls flow ip interface-full
no mls flow ipv6
mls qos
mls cef error action reset
spanning-tree mode pvst
system flowcontrol bus auto
diagnostic bootup level minimal
username dscfdscds privilege 0 password xscxzczxczxzxc18
redundancy
main-cpu
  auto-sync running-config
mode sso
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
interface GigabitEthernet1/1
description bras1gateway
mac-address 503d.e5af.9c42
ip address 10.100.100.2 255.255.255.0
load-interval 30
interface GigabitEthernet1/2
description Gatewayvlans
mac-address 503d.e5af.9c41
no ip address
load-interval 30
interface GigabitEthernet1/2.2
description vlan2gateway
encapsulation dot1Q 2
ip address x.x.67.249 255.255.255.248
interface GigabitEthernet1/2.3
description vlan3gateway
encapsulation dot1Q 3
ip address 10.160.150.1 255.255.255.0
interface GigabitEthernet1/2.4
description vlan4gateway
encapsulation dot1Q 4
ip address x.x.64.1 255.255.255.224
interface GigabitEthernet1/2.5
description vlan5gateway
encapsulation dot1Q 5
ip address 1x.x.79.1 255.255.255.224
interface GigabitEthernet1/2.6
description vlan6gateway
encapsulation dot1Q 6
ip address 1x.x.66.245 255.255.255.252
interface GigabitEthernet1/2.7
description vlan7gateway
encapsulation dot1Q 7
ip address x.x.65.249 255.255.255.248
interface GigabitEthernet1/2.8
description vlan8gateway
encapsulation dot1Q 8
ip address 10.160.160.1 255.255.255.0
interface GigabitEthernet1/3
description bras2gateway
mac-address 503d.e5af.9c43
ip address 10.200.200.2 255.255.255.0
load-interval 30
interface GigabitEthernet1/4
no ip address
interface GigabitEthernet1/5
description 7600to7200
mac-address 503d.e5af.9c45
ip address 172.30.40.2 255.255.255.252
load-interval 30
interface GigabitEthernet1/6
mac-address 503d.e5af.9c46
no ip address
shutdown
interface GigabitEthernet1/7
mac-address 503d.e5af.9c47
no ip address
shutdown
interface GigabitEthernet1/8
mac-address 503d.e5af.9c48
no ip address
shutdown
interface GigabitEthernet1/9
mac-address 503d.e5af.9c50
no ip address
shutdown
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.30.40.1
i
ip access-list extended filterips
deny   ip any host 213.8.5.42
deny   ip any host 184.170.252.36
permit ip any any
ip access-list extended rate-limit
permit ip x.x.x.x 0.0.0.31 any
snmp-server community err0r0 RO
control-plane
line con 0
password 7 11584B5643475D
logging synchronous
login
length 0
line vty 0 4
exec-timeout 357 0
password 7 07022E594207
logging synchronous
login local
transport input lat pad mop udptn telnet rlogin ssh nasi acercon
end
CPU utilization for five seconds: 89%/81%; one minute: 87%; five minutes: 76%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
170       80132      286020        280  6.47%  0.97%  0.47%   1 Virtual Exec
237      672472     2132559        315  1.43%  1.68%  1.66%   0 IP Input
   2       46200        5264       8776  0.07%  0.06%  0.05%   0 Load Meter
  27        2604       25757        101  0.07%  0.00%  0.00%   0 IPC Periodic Tim
  58         520       26336         19  0.07%  0.00%  0.00%   0 Dynamic ARP Insp
174       26276       26384        995  0.07%  0.05%  0.04%   0 Per-Second Jobs
236       14156      800538         17  0.07%  0.01%  0.00%   0 IP ARP Retry Age
   1          20          17       1176  0.00%  0.00%  0.00%   0 Chunk Manager
   3           8           6       1333  0.00%  0.00%  0.00%   0 RSVP
   4           0           1          0  0.00%  0.00%  0.00%   0 Inter Chassis Pr
   5           0          66          0  0.00%  0.00%  0.00%   0 Retransmission o
   6           0           2          0  0.00%  0.00%  0.00%   0 IPC ISSU Dispatc
   7           0           1          0  0.00%  0.00%  0.00%   0 PF Redun ICC Req
   8           0           1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
   9      372668       19347      19262  0.00%  0.39%  0.41%   0 Check heaps
  10        1340         440       3045  0.00%  0.00%  0.00%   0 Pool Manager
  11           0           1          0  0.00%  0.00%  0.00%   0 DiscardQ Backgro
  12           0           2          0  0.00%  0.00%  0.00%   0 Timers
  13        1200       10674        112  0.00%  0.00%  0.00%   0 WATCH_AFS
  14        5772       11292        511  0.00%  0.01%  0.00%   0 ARP Input
  End = e   Freeze = f
Enter Command:
plz help how to determin the high cpu cause !!
i dont knwo why th cpu got shot high !!!!!
I ran the following snmpwalk against a Cisco 7604 in my test lab...
[sfuller@rhel8 ~]$ snmpwalk ocs7604-1 1.3.6.1
SNMPv2-MIB::sysDescr.0 = STRING: Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRB7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 04-Sep-09 20:06
SNMPv2-MIB::sysObjectID.0 = OID: CISCO-SMI::ciscoProducts.658
And managed to push the CPU utilisation to 50% when it was doing little else i.e., switching traffic.
ocs7604-1#sh proc cp sort | ex 0.0
CPU utilization for five seconds: 50%/23%; one minute: 27%; five minutes: 8%
449       10312     72670        141 11.75%  6.85%  1.97%   0 SNMP ENGINE
447        8148    105812         77  5.27%  4.12%  1.28%   0 IP SNMP
191      198916   1908768        104  3.59%  2.84%  0.88%   0 IP Input
  7     1641396    120679      13601  2.31%  0.45%  0.32%   0 Check heaps
314         728       224       3250  1.51%  0.77%  0.21%   1 Virtual Exec
448        1188     52559         22  0.87%  0.66%  0.21%   0 PDU DISPATCHER
296      885668    276572       3202  0.31%  0.16%  0.15%   0 HIDDEN VLAN Proc
Based on this it's quite possible to push the CPU to very high levels if you're also routing a lot of traffic through the device.
I guess the question is who's polling and why so much?
If you run the debug netdr capture (as detailed in the link in my first response) while it's running high you should be able to see who is the source of the SNMP traffic. The following is an example while the above snmpwalk was taking place:
------- dump of incoming inband packet -------
interface NULL, routine mistral_process_rx_packet_inlin
dbus info: src_vlan 0x3F5(1013), src_indx 0xC0(192), len 0x71(113)
  bpdu 0, index_dir 0, flood 0, dont_lrn 0, dest_indx 0x380(896)
  38020000 03F50000 00C00000 71000000 00110520 0E000040 00000000 03800000
mistral hdr: req_token 0x0(0), src_index 0xC0(192), rx_offset 0x76(118)
  requeue 0, obl_pkt 0, vlan 0x3F5(1013)
destmac 00.27.0D.46.E4.40, srcmac 64.87.88.5D.5A.72, protocol 0800
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 95, identifier 0
  df 1, mf 0, fo 0, ttl 62, src 192.168.11.115, dst 192.168.2.132
    udp src 48998, dst 161 len 75 checksum 0x662A
Here we can see the packet is SNMP (destined UDP port 161) and from this we can see the source is 192.168.11.115.
9 Replies 9
Steve Fuller
Level 9
Level 9
I think this will be largely traffic related as there's no single entry in the process table that is using any amount of CPU. Take a look at the post understanding show process cpu sorted for an explanation of the two numbers seen in the CPU utilisation numbers.
Additionally you should read through the document Troubleshooting high CPU under interrupts on 7600 and 6500 boxes using "debug netdr" tool as this provides a way to determine what that traffic would be.
hi ,
could this be a bug in my platform ???
here is my ios version !!
ateway7600#sh version
Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-ADVENTERPRISEK9-M), Version 15.2(4)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 20-Jul-12 18:18 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-ADVENTERPRISEK9-M), Version 15.2(4)S, RELEASE SOFTWARE (fc1)
Gateway7600 uptime is 8 hours, 46 minutes
Uptime for this control processor is 8 hours, 46 minutes
System returned to ROM by power-on (SP by power-on)
System image file is "sup-bootdisk:c7600s3223-adventerprisek9-mz.152-4.S.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco CISCO7604 (R7000) processor (revision 2.0) with 458752K/65536K bytes of memory.
Processor board ID FOX1509G2DK
R7000 CPU at 300MHz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
1 Virtual Ethernet interface
9 Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
I think it's too early to say whether this is a bug until you've looked a little further into what could be causing the problem.
As I mentioned above, the utilisation would appear to be traffic related as the majority of the processor utilisation is Interrupt based. So some questions:
- Has the CPU suddenly increased and if so when?
- Were there any changes at or around the time of the increase?
- Is the traffic volume through the router as you would expect or has that increased?
If you run the command show int | in ^[A-Z]|put rate is there any interface that is carrying a significant volume of traffic?
If you're running MLS and NetFlow then you can also run the command show mls netflow ip nowrap and check if there is one IP address that accounts for a large volume of the traffic.
hi ,
its unstable cpu behaviuor ,
i mean that sometimes cpu gets high ,
and seems get higher quickly
if i remove the snmp it gets lower !!!
i also removed logging host x.x.x.x
also the cpu gots  lower ,
but after that , the cpu gets higher again ??!!!!!
dont know why !!!
i want to tell you something i tested
the 7600 router is connected with two identical  routers .
i mean that the 7600 is the gateway of the two other routers
the other two routers neraly carry the same number of users
about 1500 user per router and about 250 M .
the strange issue is , if i discconect the 7600 from router 1 and router 2 is connected
the cpu become 5 %
if i disconnected  router 2 and still connceting router  1  ,  the cpu still high .50-80 %
i  mean that althoug both routers are neraly identiacal , i  found that the problem is from one of the two routers.
i read  a alillte bit , i found i  need to enable fast switching !!
not sure if i must enable it on the other two routers !!!!
im really shocked !!!
output of R1 interfacve that connected with 7600
Bras1#sh interfaces gigabitEthernet 0/1
GigabitEthernet0/1 is up, line protocol is up
  Hardware is MV64460 Internal MAC, address is 0026.caf7.c01b (bia 0026.caf7.c01b)
  Description: Internet From Gateway
  Internet address is 10.100.100.100/24
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 12/255, rxload 72/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is RJ45
  output flow-control is XON, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 18/75/242/10452 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 284177000 bits/sec, 48479 packets/sec
  30 second output rate 49358000 bits/sec, 35228 packets/sec
     209485959 packets input, 1108925719 bytes, 83 no buffer
     Received 73 broadcasts, 0 runts, 0 giants, 0 throttles
     41 input errors, 0 CRC, 0 frame, 0 overrun, 41 ignored
     0 watchdog, 1944 multicast, 0 pause input
     169982882 packets output, 264503997 bytes, 0 underruns
     2 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     2 lost carrier, 0 no carrier, 0 pause output
If you run the command show proc cpu sorted | ex 0.0 a number of times, do you see the CPU utilisation going up and down, or staying up?
Also are the two numbers for the 5-second utilisation always close as they were in your first post e.g., 89%/81% or do you sometimes see the first number much higher than the second e.g., 89%/10%. In the case where the two numbers are not close what is the entry in the process table that's using the CPU?
hi , not always the numbers are close .!! i mean sometimes ths two numbers are close and sometimes no !
i mean , now , at this moment its stable ,
Gateway7600#show proc cpu sorted | ex 0.0
CPU utilization for five seconds: 25%/23%; one minute: 28%; five minutes: 29%
237     1008688     3053126        330  1.03%  1.54%  1.46%   0 IP Input
434      172868       17712       9759  0.31%  0.16%  0.16%   0 HIDDEN VLAN Proc
CPU utilization for five seconds: 28%/26%; one minute: 28%; five minutes: 29%
237     1008800     3053480        330  0.87%  1.49%  1.45%   0 IP Input
237     1008832     3053621        330  0.87%  1.49%  1.45%   0 IP Input
CPU utilization for five seconds: 32%/28%; one minute: 28%; five minutes: 29%
237     1008900     3053998        330  1.19%  1.47%  1.44%   0 IP Input
434      172888       17717       9758  0.31%  0.16%  0.16%   0 HIDDEN VLAN Proc
237     1008916     3054230        330  1.19%  1.47%  1.44%   0 IP Input
434      172888       17718       9757  0.31%  0.16%  0.16%   0 HIDDEN VLAN Proc
CPU utilization for five seconds: 36%/32%; one minute: 29%; five minutes: 30%
   9      479456       24985      19189  1.59%  0.49%  0.42%   0 Check heaps
237     1009140     3054796        330  0.47%  1.39%  1.43%   0 IP Input
CPU utilization for five seconds: 34%/29%; one minute: 29%; five minutes: 30%
170       16568        5289       3132  1.83%  0.45%  0.10%   1 Virtual Exec
237     1009200     3055028        330  1.83%  1.42%  1.43%   0 IP Input
   9      479456       24985      19189  0.63%  0.50%  0.42%   0 Check heaps
434      172908       17722       9756  0.39%  0.16%  0.16%   0 HIDDEN VLAN Proc
170       16636        5294       3142  1.83%  0.45%  0.10%   1 Virtual Exec
237     1009268     3055309        330  1.83%  1.42%  1.43%   0 IP Input
434      172908       17723       9756  0.39%  0.16%  0.16%   0 HIDDEN VLAN Proc
CPU utilization for five seconds: 33%/30%; one minute: 29%; five minutes: 30%
170       16692        5299       3150  1.67%  0.55%  0.13%   1 Virtual Exec
237     1009296     3055406        330  0.71%  1.37%  1.42%   0 IP Input
Gateway7600#
i monitor the cpu process live , by the command
show process cpu monitor
dont  knwo why suddenly it gets high !!!
also , im really surprised .
why snmp cause high cpu ??!!!!!
hi steve ,  the cisco 7600 now is stable .
i dont know why ??!!!
im also afraid to enable snmp agian ,  but i will start hitting the books about cpu usgae in7600 and read more
thanks alot for interest  and replies
with my best regards
