08-27-2015 05:45 AM - edited 03-08-2019 01:32 AM
Hi. I first would like to point out that i did not configure these switches, i inherited them. So here goes.
We are getting a lot of out discard errors on all our edge switches. Our edge switches are all 2960x's and are stacked (there are about 3 or 4 per stack). We have 11 edge switch locations. I believe it has to do with our qos setup.
We currently have mls qos enabled and here is the config for that portion:
mls qos map cos-dscp 0 8 16 24 32 46 46 56
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
Here is one of the ports that have the issue:
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize OutDiscards
Gi2/0/30 0 0 0 0 0 13005659
Port Configuration:
Current configuration : 284 bytes
interface GigabitEthernet2/0/30
switchport trunk native vlan 120
switchport mode trunk
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust dscp
auto qos trust
storm-control broadcast level 60.00
spanning-tree portfast
spanning-tree bpduguard enable
end
GigabitEthernet2/0/30 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 38ed.1824.e61e (bia 38ed.1824.e61e)
MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 1w0d, output hang never
Last clearing of "show interface" counters 4w2d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 13005659
Queueing strategy: fifo
Output queue: 0/40 (size/max)
12505 packets input, 2199739 bytes, 0 no buffer
Received 1709 broadcasts (1008 multicasts)
0 watchdog, 1008 multicast, 0 pause input
12616125 packets output, 2153347204 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Any ideas?
And yes, the workstation is currently unplugged from the port at the moment. Duplex and Speed are set to auto, although i have noticed the wrong port speed gets assigned sometimes. In this case, it is set to full duplex and 1000 speed.
08-31-2015 01:12 AM
Try hard coding at both sides.
08-31-2015 04:43 AM
Selecting port speed and duplex manually, causing the port to go down.
08-31-2015 05:51 AM
both sides?
08-31-2015 07:05 AM
Yes, sir.
Switching it back to auto will get it back on 1Gbps/Full.
08-31-2015 07:19 AM
What version of IOS are you using?
08-31-2015 07:24 AM
Version 15.0(2)EX5
I know there is a higher version, but we had to downgrade due to an issue of the switch stacks rebooting when logging into them. (Known Issue)
08-31-2015 07:28 AM
Ok, so you've cleared the counters, removed QOS from the port, shut then no shut, hard coded etc. etc. Could this possibly be related to the PC at the other end and not the switch? Do any other ports show the same behavior? Generally the output discard means that your sending more traffic than the port can cope with. Looks like something funny is going on with your speed and duplex settings.
08-31-2015 08:07 AM
Its the same behavior across multiple devices AND multiple switch stacks. The only thing that is constant is that they are all 2960x's.
08-31-2015 08:09 AM
Also, i meant to add that we happen to be testing on a port connected to a workstation, but its not limited to the workstations. VoIP phones, AppleTVs, and other network devices are show the similar behavior. (Some are 100Mb devices, and others are 1Gbps)
08-27-2015 12:38 PM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You might just be bumping into a not uncommon issue on the 2960 (and 3560/3750), insufficient egress interface buffer RAM to deal with bursting.
If you really don't need to use QoS, disabling it often avoids the issue because buffer RAM isn't reserved for every port's four egress queues.
If you do need QoS, then buffer tuning might decrease your drops too. Unfortunately, buffer tuning isn't for the novice, and one-size doesn't fit all.
A good document: https://supportforums.cisco.com/document/31581/egress-qos
