high temperature...
IngGerardo013
Hello Guys,
They told me to check a switch ws-2980G-A (I think it is very old model) because it was not working, executing some commands and watching that air sytem neither was not working I did realise that temperature was in 84Cº!!,.Aafter disconnect the device for some time and reconnect it it worked again, now I would like to know if the switch will continues working normal if the air system is fixed, or if the switch was damaged (how can i know?) for that high temperature, or if the switch needs to be changed due to switch is old.  any advise would be appreciated.
Reza Sharifi
Keep it running and keep an eye on it and if the switch is running normal after a week or 2 then it is probably fine.  If you turn it on and see the temperature is high than you need to replace it.
Reza
