Home Lab Configs Wrong? HELP PLEASE!!!
g3nz0d227
Community Member
Hi. I'm trying to configure my home lab switch, but i'm not sure if it's right.
I have a NAC device with an IP of 192.168.0.10 (used as UN for the device's login), and I assigned that IP as VLAN 1 (192.168.0.10 /24).
Is this an issue? Should I set VLAN 1 to 192.168.0.0 /2?
Also,
The switch WILL NOT accept the crypto key generate command per SSH. I can't even telnet into the device as the session quickly disconnects after telnetting in.
Please help. Here are my configs:
User Access Verification
Password:
Password:
CAHN>en
Password:
CAHN#sh run
Building configuration...
Current configuration : 2747 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname CAHN
enable secret ********
enable password *********
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip routing
no ip domain-lookup
ip domain-name homelab.com
ip dhcp excluded-address 192.168.0.1
ip dhcp excluded-address 192.168.0.10
ip dhcp pool production
network 192.168.0.0 255.255.255.0
domain-name wr
lease 3
ip dhcp pool PROD
default-router 192.168.0.1
lease 3
ip dhcp pool management
lease 3
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
description to Eth0 on CT
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
description SPAN PORT
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
description Link to ISP Router
interface GigabitEthernet0/1
switchport nonegotiate
interface GigabitEthernet0/2
switchport trunk allowed vlan 1
interface Vlan1
ip address 192.168.0.10 255.255.255.0   (is this correct? Can the VLAN 1 IP be the same as what I assigned the NAC device?)
ip default-gateway 192.168.0.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip http server
snmp-server community private RW
snmp-server community private1 RO
snmp-server enable traps snmp linkdown linkup
snmp-server enable traps mac-notification
snmp-server host 192.168.0.10 private
control-plane
banner motd ^CCCHome Network.^C
line con 0
exec-timeout 5 0
password **********
logging synchronous
login
line vty 0 4
exec-timeout 5 0
password **********
login
transport input telnet (SSH UNSUCCESSFUL HERE, HENCE THE TELNET)
line vty 5 15
--More--
chrihussey
No the switch interface VLAN 1 IP cannot be the same as the NAC device.
You probably can't generate the crypto key because the code on the switch does not support it. (The image probably should have a "k9" in the name)
According the the config the telnet session should drop after 5 minutes of inactivity "exec-timeout 5 0", if this isn't the case something is wrong. Suggest removing it from the VTYs.
Hope this helps.
