Host to other Switches?
vranxid01
               Hello, I'm trying to ping the Call Center Switch and the Engineering sw from IT and it should be successful
      (phase 5 testing) I applied the acl correctly and checked the ip route & it's ok, however it still does not work. Here's the pkt
cadet alain
Where is it asked to test pings to switches in the doc you sent us ?
Alain
