Hosts in Campus Network Unreachable from WAN
Rob Cluett
I created a simple Campus Network with two hosts (lxc-2 and lxc-3) connected to the access layer switches. Each host is in it’s own vLAN (vLAN 11 and vLAN 12) and is mounted in Rack A. The distribution/core devices are layer 3 switches running OSPF.
I can ping the hosts from the Layer 3 distribution/core switch (i.e. CTvSWT01 and CTvSWT02) but cannot ping the hosts from the WAN (i.e. CTvRTR01 or CTvRTR02).  Any ideas why the anomaly exists or what I might be overlooking?
Attached is a network map and the access layer, distribution/core layer and WAN device configs.
- Rob
Just noticed the route you have added on the hosts is wrong.
You have put 10.0.0.0/16 but it should be 10.0.0.0/8 for it to work or you could just use a default route.
Jon
18 Replies 18
Hello
Curious, Can you ping the access layer sourced from the switches SWXT01 - 2 gig0/1
Disable Ip routing on the access layer switches as they are running as host switches and dont need to perform routing. Function.
I see hrsp active on the distribution switches but no preemption, so by default hrsp will default to the highest IP of the group in this case CTcSWT01, shouldn’t make any difference to the connectivity at this time but it worth mentioning.
Looks like your implementing ospf broadcast network, as such are the CTvRTR01 -2  DR-BDR for the distribution switches?
res
Paul
Kind Regards
Paul
Thanks for the response Paul.
1) "ip routing" can't be disabled on the access layer switches. It kills my Out-of-Band access into each switch. I believe that Cisco VIRL in software is using routing to access these virtual devices.
2) "preemption" is now enabled on each vLAN of the CTvSWT01 distribution layer switch.
3) "ping" of the access layer switches from the distribution layer switches CTvSWT01 and CTvSWT02 (Source is gi0/1 on each):
From CTvSWT01:
CTvSWT01#ping
Protocol [ip]:
Target IP address: 10.24.1.5
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: GigabitEthernet0/1
Sending 5, 100-byte ICMP Echos to 10.24.1.5, timeout is 2 seconds:
Packet sent with a source address of 10.24.128.17
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/2 ms
From CTvSWT02:
CTvSWT02#ping
Protocol [ip]:
Target IP address: 10.24.1.6
Repeat count [5]:
Sending 5, 100-byte ICMP Echos to 10.24.1.6, timeout is 2 seconds:
Packet sent with a source address of 10.24.128.21
Success rate is 100 percent (5/5), round-trip min/avg/max = 2/2/3 ms
4) For OSPF Neigbors on distribution switch CTvSWT01:
Neighbor ID     Pri   State           Dead Time   Address         Interface
CTvRTR01      1   FULL/BDR        00:00:39    10.24.128.18    GigabitEthernet0/1
CTvSWT02      1   FULL/DR          00:00:34    10.24.12.3        Vlan12
CTvSWT02      1   FULL/DR          00:00:33    10.24.11.3        Vlan11
CTvSWT02      1   FULL/DR          00:00:34    10.24.1.3          Vlan1
For OSPF Neigbors on distribution switch CTvSWT02:
CTvRTR02       1   FULL/DR          00:00:38    10.24.128.22    GigabitEthernet0/1
CTvSWT01      1   FULL/BDR        00:00:34    10.24.12.2        Vlan12
CTvSWT01      1   FULL/BDR        00:00:33    10.24.11.2        Vlan11
CTvSWT01      1   FULL/BDR        00:00:36    10.24.1.2          Vlan1
Hello
Cheers for the validation- so this means the rtrs L3 from their direct links to the distribution switchs will work and maybe this is just missing advertised prefix
i suppose you've pinged with source testing from tthe other L3 interfaces?
What exactly is failing
res
paul
Kind Regards
Paul
Thanks Paul.
Yes. It works for VLAN 1 when the access layer switch vLAN 1 IPs are the destination.  The two hosts in question are in vLAN 11 and 12 with IPs 10.24.11.100 and 10.24.12.100 respectively.  They do not work when pinging from the routed network/devices but are pinging from the switched networks/devices.  So, it fails from the two wan routers but is a success from the two distribution switches they are connected to. The reason why it's failing isn't obvious to me since I believe I have all the devices configured appropriately.
From the RTR (CTvRTR01) <-- Fails
CTvRTR01#ping
Protocol [ip]:
Target IP address: 10.24.12.100
Repeat count [5]:
Ingress ping [n]:
Sending 5, 100-byte ICMP Echos to 10.24.12.100, timeout is 2 seconds:
Packet sent with a source address of 10.24.128.10
Success rate is 0 percent (0/5)
From the switch (CTvSWT01) <-- Success
CTvSWT01#ping
Protocol [ip]:
Repeat count [5]:
Sweep range of sizes [n]:
CTvSWT01#
Jon
Jon Marshall
In addition to Paul's suggestions have you checked the default gateways on the clients are set correctly ?
A bit obvious I know but it can be easily done.
Jon
Thanks for the response Jon.
The LXC's are configured as follows (IP and default gateway).  Below is just a simple script that turns up the Ethernet interfaces on each:
For LXC-3
    #!/bin/sh
    ifconfig eth1 up 10.24.12.100 netmask 255.255.255.0
    route add -net 10.0.0.0/16 gw 10.24.12.1 dev eth1
    exit 0
and for LXC-2
    #!/bin/sh
    ifconfig eth1 up 10.24.11.100 netmask 255.255.255.0
    route add -net 10.0.0.0/16 gw 10.24.11.1 dev eth1
    exit 0
What happens if you ping the hosts from the core/district switches but use source interface as the one connecting to the routers ?
Jon
Rob Cluett
Thanks Jon.  You're correct.  It now works from the routed network having changed the mask to /8 on the hosts.  Good stuff. Paul, thank you to you too!
Hello
No problem - glad it's sorted
@Jon -Well spotted mate
res
paul
Sent from iPhone
Kind Regards
Paul
Hi Paul
Thanks.
I'm on an iPhone like you but not using app yet as locked out apple App Store (forgot password for Apple ID).
Does it make it easier to use the site ?
And how are the CCIE studies going !
Jon
Hello Jon
Only noticed your question regards my studies mate - apologies for replying.
Basically they have been on hold -due to work, family commitments....I even took about 4 months off here which is very unusual - i am in no rush.
I see you a super blue now or have you been for a while, I guess your going for that magical 40K mark then?
res
Paul
Kind Regards
Paul
Hi Paul
I think the no rush attitude is the best way to approach it to be honest and it means we see more of you on here :)
I am in no rush to get to the next badge which is just as well as I don't seem able to score as I did in previous times !
Jon
Rob Cluett
I guess I spoke too soon.  It partially works.  I'm able to ping one minute then not able to the next.  Almost appears like a flapping link but would be no such thing in Cisco VIRL. Any idea's why it might work then fail?
CTvRTR01#ping 10.24.11.100
Sending 5, 100-byte ICMP Echos to 10.24.11.100, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/7 ms
