Hot add stack connection
kisankagr
Frequent Visitor
Frequent Visitor
We have a three 3850 switch stack connected non-redundant half bandwidth.
Switch #    Port 1        Port 2
1            2            None
2            3            1
3            None        2
We need to connect Switch# 3 to Switch#1 to make the stack redundant and full bandwidth.
Will this be possible do online without any downtime?
Cheers
2 Accepted Solutions
you should be able to connect switch 3 to switch 1 without affecting the rest of the stack. As far as I am aware you don't need to reload the switches
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I cannot say for the 3850, but I recall the 3750 advised to only connect/disconnect stack cables if one side of the connection (one of the stack members) was powered off.
Also, at least for the 3750, you didn't need to reload the whole stack.
7 Replies 7
You need to reboot the switch after stacking configuration to take the effect.
So this is not possible to do online without  downtime.
Sam
In this particular case, the 3 switches are ALREADY in a stack, so adding the cable will not have any impact, other than permitting normal operation in the event one of the OTHER cables or stack interfaces fail.
Ganesh Hariharan
Have a look on the below link with standard set of procedure to add or remove switches form stack.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/hardware/installation/guide/b_c3850_hig/b_c3850_hig_chapter_010.html
Hope it Helps..
-GI
Rate if it Helpss
Thank you all for the replies, I'm going to try this today
Hi, I have to do the same exact thing, could you tell if it has worked without rebooting your stack?
Joseph W. Doherty
Disclaimer
Posting
