Hot stand by and cold stand by
pselva2000
can I ask what is difference bewteen hotstandby and coldstandby in supervisor module
1   Standby Supervisor  RPR                 Standby cold
2   Active Supervisor   RPR                 Active
Reza Sharifi
When RPR mode is used, the standby supervisor engine partially boots and keeps synchronized copies of the active configuration, which shortens the time needed to bring up the standby supervisor engine and have it start handling traffic from 1.5 minutes (for a cold boot on the standby) to 30 seconds (to finish the boot and re establish links). Hot standby applies to SSO mode.  If possible use SSO instead of RPR.
Reza
