How bad is my C3560X-48P-S? Only SYST LED Fast Blinking [Solved: RMA Processed]
Carlos Espino
Hi, thank you in advance for your time reading this post, I have a C3560X-48P-S that works for almost 3 years without problems until now, the actual led status is SYST LED on fast blinking and no additional leds or ports leds or activity with ethernet cables connected, the PS seems working ok and when I accesed via USB Console, I did it via com3 but got this message after " switch: reset "
switch: reset
Are you sure you want to reset the system (y/n)?y
System resetting...
Using driver version 3 for media type 1
Invalid parameter block -- no mac address available.
Xmodem file system is available.
Can't set variable with illegal char "▒" (0xffffffff) in name.
Can't set variable with illegal char "▒" (0xfffffff7) in name.
Can't set variable with illegal char "▒" (0xffffffef) in name.
Can't set variable with illegal char "▒" (0xffffffe7) in name.
Can't set variable with illegal char "▒" (0xffffffdf) in name.
Can't set variable with illegal char "▒" (0xffffffd7) in name.
Can't set variable with illegal char "▒" (0xffffffcf) in name.
Can't set variable with illegal char "▒" (0xffffffc7) in name.
Can't set variable with illegal char "▒" (0xffffffbf) in name.
Can't set variable with illegal char "▒" (0xffffffb7) in name.
Can't set variable with illegal char "▒" (0xffffffaf) in name.
Can't set variable with illegal char "▒" (0xffffffa7) in name.
Can't set variable with illegal char "▒" (0xffffff9f) in name.
Can't set variable with illegal char "▒" (0xffffff97) in name.
Can't set variable with illegal char "▒" (0xffffff8f) in name.
Can't set variable with illegal char "▒" (0xffffff87) in name.
Can't set variable with illegal char " (0x7f) in name.
Can't set variable with illegal char "▒" (0xfffffff4) in name.
Can't set variable with illegal char "/" (0x2f) in name.
Can't set variable with illegal char "'" (0x27) in name.
Can't set variable with illegal char "" (0x1f) in name.
Can't set variable with illegal char "" (0x17) in name.
Can't set variable with illegal char "" (0x0f) in name.
Can't set variable with illegal char "" (0x07) in name.
The password-recovery mechanism is enabled.
The "MAC_ADDR" environment variable is not set.
Initializing Flash...
mifs[2]: 1 files, 1 directories
mifs[2]: Total bytes : 6838272
mifs[2]: Bytes used : 1956352
mifs[2]: Bytes available : 4881920
mifs[2]: mifs fsck took 1 seconds.
...done Initializing Flash.
done.
Loading ""...: no such device
Error loading ""
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
Any idea to get back to life?
Thanks in advance!
Carlos Espino
19 Replies 19
Please try what Iulian suggested, if not working, may be power it off completely wait for a few mins and try bringing it up to see flash getting detected.
Will try with that and post results.
TeraTerm seems to be the one! Let se if it boots now and let you know.
Thanks Lulian!
Here is the result after boot xmodem: with file c3560e-ipbasek9-mz.150-2.SE9.bin
Not look good, maybe is the wrong boot file, dont know.
switch:
switch: boot xmodem:
Loading "xmodem:"...Begin the Xmodem or Xmodem-1K transfer now...
C@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "xmodem:" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3560E Software (C3560E-IPBASEK9-M), Version 15.0(2)SE9, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 01-Dec-15 06:47 by prod_rel_team
HULC:Collect Entropy thread starting on box...
Initializing flashfs...
mifs[4]: 1 files, 1 directories
mifs[4]: Total bytes : 6838272
mifs[4]: Bytes used : 1956352
mifs[4]: Bytes available : 4881920
mifs[4]: mifs fsck took 0 seconds.
mifs[4]: Initialization complete.
Can't set variable with illegal char "" (0xFFFFFFFF) in name.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not required (Stage 2)
FIPS: Fatal failure: sp800108 failed
%Software-forced reload
00:00:19 UTC Mon Mar 1 1993: Unexpected exception to CPUvector 2000, PC = 26A5C08
-Traceback= 0x26A5C08z 0x20F8494z 0x20F7DA8z 0x1C049B4z 0x1C04B74z 0x1C04C90z 0x4F1EB0z 0x4F2118z 0x26A6EECz 0x26A14A0z
00:00:19 UTC Mon Mar 1 1993: Unexpected exception to CPUvector 2000, PC = 26A6EC8
-Traceback= 0x26A6EC8z
=== Flushing messages (00:00:19 UTC Mon Mar 1 1993) ===
Buffered messages:
Queued messages:
*Mar 1 00:00:19.369: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar 1 00:00:16.844: Read env variable - LICENSE_BOOT_LEVEL =
*Mar 1 00:00:16.844: %LICENSE-2-VLS_ERROR: 'VLSaddLicenseStorage' failed with an error - rc = 145 - 'Error[145]: Failure in creating/opening the store.'
-Traceback= 4E275Cz 1FF34z BA70z 4F1C78z 4F2118z 26A6EECz 26A14A0z
*Mar 1 00:00:16.844: %HULC_LICENSE-1-LICENSE_REGISTER_FAILED: license register license storage 'flash:' failed - rc = 24
*Mar 1 00:00:16.852: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3560x Next reboot level = lanbase and License = No valid license found
Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
SRR0 = 0x01C46588 SRR1 = 0x00029230 SRR2 = 0x026A5C08 SRR3 = 0x00029230
ESR = 0x00000000 DEAR = 0x00000000 TSR = 0x84000000 DBSR = 0x10000000
CPU Register Context:
Vector = 0x00002000 PC = 0x026A5C08 MSR = 0x00029230 CR = 0x24002022
LR = 0x026A5BA4 CTR = 0x004CED40 XER = 0x20000050
R0 = 0x026A5BA4 R1 = 0x04AA4410 R2 = 0x00000000 R3 = 0x041B3A9C
R4 = 0x00000000 R5 = 0x00000000 R6 = 0x04AA43E0 R7 = 0x04190000
R8 = 0x00029230 R9 = 0x04190000 R10 = 0x00029230 R11 = 0x00000000
R12 = 0x24002028 R13 = 0x0B981A10 R14 = 0x004F20D0 R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
R24 = 0x00000000 R25 = 0x00000000 R26 = 0x04AA44B0 R27 = 0x03D90000
R28 = 0x00000009 R29 = 0x040F3624 R30 = 0x03D90000 R31 = 0x00000000
Stack trace:
PC = 0x026A5C08, SP = 0x04AA4410
Frame 00: SP = 0x04AA4420 PC = 0x026A5BA4
Frame 01: SP = 0x04AA4428 PC = 0x020F8494
Frame 02: SP = 0x04AA4430 PC = 0x020F7DA8
Frame 03: SP = 0x04AA4440 PC = 0x01C049B4
Frame 04: SP = 0x04AA4460 PC = 0x01C04B74
Frame 05: SP = 0x04AA4478 PC = 0x01C04C90
Frame 06: SP = 0x04AA44A8 PC = 0x004F1EB0
Frame 07: SP = 0x04AA45B0 PC = 0x004F2118
Frame 08: SP = 0x04AA45B8 PC = 0x026A6EEC
Frame 09: SP = 0x00000000 PC = 0x026A14A0
Switch uptime is 19 seconds
cisco WS-C3560X-48P (PowerPC405) processor with 262144K bytes of memory.
Maybe there's more damage to the flash than just the parameter block...  I also found this (not really helpful though):
https://quickview.cloudapps.cisco.com/quickview/bug/CSCui99896
It can't hurt trying another IOS - c3560e-ipbasek9-mz.122-55.SE10.bin is recent enough and significantly smaller than 15.0(2)SE9, so it'll take less time to load via xmodem.
