03-02-2017 12:25 PM - edited 03-08-2019 09:35 AM
03-02-2017 04:15 PM
John, if you want some help then you might need to provide a bit more information. A DHCP relay is just that. The packet will be sent as a unicast to the destination. If that destination is though a tunnel then that should work OK. But if you give us diagram and some configuration info that is not working maybe somebody can help you
03-03-2017 02:27 AM
Any ideas?
Hi ,
Have a look on below post for more clarification and Help..
https://supportforums.cisco.com/discussion/11145841/dhcp-relay-through-gre-over-ipsec
Hope its Helps..
-GI
