Bookmark
Subscribe
1898
How can I get a Cisco 3850 to allow 30W per port power distribution without using CDP or LLDP power negotiation?
NateRoth36924
I have a WS-C3850-24P that I need to fully load via PoE. I need to do this to test a power supply (like a UPS) that in turn powers the switches power supplies. I have a 715W and 1100W PSU in my PoE switch. This should afford me the full 720W PoE budget. On the output side of the switch I have a PoE load bank. It is a device meant to test and load down PoE switches. It however, does not support LLDP. This means by default I am stuck with 15W per port that is allocated to class 4 or unclassified devices. How can I tell the switch to allow full power delivery (30W per port) without having to negotiate via CDP or LLDP?
Reza Sharifi
Under the interface, can you use "power inline static" command?
Reza Sharifi
