06-13-2015 05:49 AM - edited 03-08-2019 12:32 AM
I can connect to a 3750 switch and there is another 2960 switch connected to this switch.
The port of 3750 switch connected to 2960 switch is an access vlan 106.
There is a SVI interface ( vlan 110) in 3750 switch with ip address 10.0.1.75 that is management ip address i can connect to it.
When i do show cdp neighbor detail i see the ip address of 2960 switch is 172.16.1.30 but i can't ping this ip address from 3750 switch and i can't connect to it from my computer.
Is there any solution that I can get an ip address from 2960 switch to test connectivity to this switch?
Thanks in advance,
06-13-2015 08:34 AM
put the port connecting both switches in trunk mode and create an SVI for Vlan 110 on the 2960 Switch and you'll be able to connect to it.
Alain
06-13-2015 09:06 AM
Thanks for your response
But i cant connect to 2960 switch for doing any action, I know there is SVI interface on it and i think it's interface vlan 110. I want to know how can i find ip address of this interface vlan? How can i get this kind of information from 3750 switch?
06-13-2015 10:06 AM
show cdp neighbor detail should give you this info.
Alain
06-13-2015 09:23 PM
I had done show cdp neighbor detail and I had found an ip address like 172.16.2.1.
The 3750 interface SVI was 10.0.1.75, anyway with this configuration I couldn't connect to 2960 switch.
Is there any command or method that I can get another ip address maybe vlan 110 ip address of 2960 switch(management SVI)?I think this ip address should be in subnet 10.0.1.0/24 that i can connect to it, because in 3750 there is no route.
06-14-2015 12:52 AM
Murtaza,
Sorry there is no way to get the ip address of thst vlan from 3750 switch.
Hth
