how can i redundant my uplinks?
dsolangon
The scenario is i have one layer3 3com connected to two High availability ASA. What is the best practice configuration for the uplinks of the 3com switches going to my ASA?
Yep - that's what I meant.
I would imagine the asa inside interface config looking something like this, with 10.1.1.2/29 configured on the 3com switch virtual interface:
interface FastEthernet0/1
no nameif
no security-level
no ip address
no shut
interface FastEthernet0/1.3
description Uplink to 3com LAN switch
vlan 3
nameif INSIDE
security-level 100
ip address 10.1.1.1 255.255.255.248 standby 10.1.1.3
I seem to recall there is an functional impact depending upon where you place the nameif command. If put under the main interface, instead of subinterface, then I think the ASA will also send untagged traffic as well as tagged. Might be one to check out yourself.
9 Replies 9
Abzal
Level 7
Level 7
Hi Daryl,
What is model of your ASAs? And 3com? Is second ISP used as backup?
Abzal
Best regards,
Abzal
shillings
Level 4
Level 4
I would configure the 3com uplinks as dot1q trunks to each asa. Then select a VLAN ID and create it a layer-3 virtual interface on the 3com and assign /29 address.
Presuming the ASA is not a 5505, then I'd configure the inside as a subinterface and match the VLAN ID to the 3com. Then add another /29 address here.
(optional) Configure a standby ip on the same subinterface using a 3rd /29 address. This is so the standby asa can monitor the active unit via its inside interface.
That would be how I'd do it, but interested in any other suggestions.
@shillings
So you mean i iwill configure my asa with sub int using the same vlan of 3com up link switch and make it layer 3? Please see the attached img
no nameif
no security-level
no ip address
no shut
vlan 3
nameif INSIDE
security-level 100
Can we load balance the uplinks of the switches?
Do you mean the outside of your ASAs where you have a couple of router icons?
Yes each asa have 1 different ISP provider
Do you use Provider Independent IPs?
Are the two Internet edge routers yours or your ISPs?
I was pointing on the uplinks of the switch going to. The firewall can i load balance the traffic ?
