How can I script a ping test to a number of hosts?
bruce.porter
I would like to test the network links from the perspective of the host's receivers, Windows and Linux boxes. I am looking for an analysis of packet losses.
Is there a good way to test this? Would a ping test do it? Can a ping test be scripted from the router?
There are no errors on the receive ports of the switches, 6513s and 4506s.
By the way, I now believe in cleaning the fiber ends prior to inserting them in ports. I have use optics alcohol cleaning pads, but this is discouraged by Cisco. They also discourage liquid air. They prefer the dry cartriges.
I purchased a Fluke DTX-1800 cable tester. This gives me a pulse of the link quality. I live in the aerospace world.
desai.jaideep
Level 5
Level 5
I would advice the use of SLA monitoring in ur equipment. just need to check out that its available in ur IOS.
Check the command "ip sla".
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_configuration_guide_book09186a00802b2a6c.html
Secondly there are host of tools comming which can monitor through pings link DUDE and WhatsUP.
Hope that will help.
JD
Thanks for the reply. I don't have the VoIP software SLA though. I couldn't locate DUDE either. We do have WhatsUP but it will present a problem in my case because I can only reach the devices from their default gateways because of firewalls running on these hosts.
There are a couple of new options though. One is tclsh. This stands for Tool control language shell. It is available in IOS 12.3(2)T.
R1#tclsh.
http://blog.sazza.de/?cat=10 This page shows you how to use the command and another command called "macro".
I don't have either capability in my version. So I am still researching.
