how can I see bandwidth utilization on a layer 3 port of a switch?
yuhuiyao
All,
Is there a way to see the bandwidth usage on a layer 2 port of a switch? I have tried, not working.
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
L3 in Switched: ucast: 54217685 pkt, 15613598253 bytes - mcast: 0 pkt, 0 bytes
L3 out Switched: ucast: 49891888 pkt, 12027617095 bytes - mcast: 0 pkt, 0 bytes
    54537044 packets input, 16667165219 bytes, 0 no buffer
    Received 279044 broadcasts (74600 IP multicasts)
    50031279 packets output, 13048119837 bytes, 0 underruns
    44 output errors, 60 collisions, 0 interface resets
    0 babbles, 44 late collision, 0 deferred
    0 lost carrier, 0 no carrier
Giuseppe Larosa
Answered in WAN forum
you should avoid to create multiple threads in multiple forums
Best Regards
Giuseppe
