How can I un-stack 2 switches
Andy White
Level 3
Level 3
I have been given 2 x 3750 switches that were a stack, I need to keep the configs on both but how do I make them individual switches again and remove the stack info?
When I try to remove the switch from the stack I get this error:
%IDBs can not be removed when switch is active
Any ideas?
1.  Power down the 2nd switch;
2.  Remove the statement "switch 2 provisioning" ... using the "no switch 2 provisioning" command;
3.  Remove the stacking cable from the 2nd switch;
4.  Power up the 2nd switch and in configuration mode use the command "switch 2 renumber 1"; and
5.  Reboot switch #2.
