How could I add 4 switches to an existing stack?
Zagam
Hi there,
Could you help me? I have this scenario, a stack from 2 switches, one switch is the master with 15 priority, the second with 14 priority, I want to add 4 new switches to existing stack.
1.- How could I do that?
2.- I need to add one by one or could I add all in the same time?
PD: All my siwtches are updated and are in the same IOS (switches 3650).
Best Regards.
Francesco Molino
You can provision the new switches, set the priority to each of them lower than what's existing.
Connect them and you're ready to go.
Here a documentation explaining the while process:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/71925-cat3750-create-switch-stks.html#anc16
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
I agree, nothing special adding those new 4s
