How could I check that either the line card's problem or not?
foster
Hi there
we find out that the line card's hardware problem recently
so replace from the fault device to new device
at that time we can't not realize that how can I check the line card's problem or not
some line card are check this way
but I'm not sure that is best way either hardware's problem or not
# Check this output in the list of registers. If the settings in this output are non-zero, it indicates that there were drops due to the buffer overrun.
Cat6500# show counters interface gigabitEthernet <mod/port> | include qos3Outlost
51. qos3Outlost = 768504851
http://www.cisco.com/en/US/customer/products/hw/switches/ps708/products_tech_note09186a00801751d7.shtml
line card's mode is WS-X6148A-RJ-45 and WS-X6148-RJ-45
regards
haksung
7 Replies 7
Mahesh Gohil
Level 7
Level 7
Hi haksug,
As much as i know whenever I face any problem with service running on line card I normally contact Cisco TAC and then they come up with justification that it is problem with Linecard, SIP or Chassis.
This is what I do.
Mahesh
kapathak
Hi Haksung,
Usually if you notice any problems on a line card, there will be an accompanying error message in the logs. You can paste the error message in the Error Message decoder tool available at cisco.com
You can also use show diagnostic result module module-number detail to see if the line card has failed a particular test.
If you do not find much info online, you can always contact TAC :-)
Kapil
Leo Laohoo
Ummmm ... You are not connecting your high-speed servers to this blade are you?
Like Leo said, if you are connecting servers into the 6148 line cards, it means you are running into oversubcription problem.
HTH,
jerry
JEEEEEEEEEEEEEEEERRRRRRRRRRRRRRRRRRRRRRRRRRRYYYYYYYYYYYYYYYYYYYYYYYYYYYYY!
Where have you been hiding!  Haven't seen your posts for a long time.
Hey Leo, I was busy with customer stuffs. Came back to the forum recently and trying to answer the Nexus questions...
Hi Haksung,
You can try to re-seat the module and run full diagnostics and observe if it passes all tests. If not then the raise a Cisco TAC will be next step to replace the line card.
Please mark accordingly if it helps.
Sukanta
