How do do port channels on a 3750 stack?
joerggrau
I have a couple of 3750 stacks.
I am trunking them together (I am runnign BGP on each of them with seperate providers and AS numbers...)
I am trying to set up some redundancy int he trunks so should one of the 3750s fail, the trunk will remain up.  I tried to set up a port channel group (L2 Ether Channel) across the two blades (one port on 3750 A and one on 3750 B), but that seems to be illegal.
Does anybody know how I can configure a L2 port channel across a 3750 stack?  Or something similar that achieves redundancy?
thanks
Joerg
Jon Marshall
Joerg
Have you used this doc as a config guide -
3750 cross stack ethercherchannel
Jon
Ganesh Hariharan
thanks
Joerg
Hi Joerg,
Check out the below link also with sample example and configuration of etherchannel in 3750 switches.
http://docs.google.com/viewer?a=v&q=cache:SDcW6L7vPgYJ:https://www.cisco.com/application/pdf/paws/69979/cross_stack_etherchannel.pdf+sample+etherchannel+configuration+3750+stack&hl=en&gl=in&pid=bl&srcid=ADGEESi375x_AXG01ePZBL-54nmxS7HOMs5LgkjUpQXGfl-...
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
