How do I access devices on router plugged into switch
I have a Cisco catalyst 2960 switch si Poe-8. I’m new at this and have a question.  My switch is set up with up vlan IP address 192.168.0.1. I have a WiFi router plugged into the switch the router uses 192.169.1.1.  If I plug a ip camera into the router I am unable to access it from computer connected to the switch. Only from the WiFi network. How to I set the switch up so I can access devices on my router different vlan.
Richard Burts
We need to know a bit more about your environment before we can offer really good advice. You describe a switch with a vlan and an IP address on that vlan. Then you describe a wifi router using an address in a different subnet. You do not tell us whether that wifi router is in the same vlan or is in a different vlan.
Rick
Rick
I have a Cisco switch that I set up for home use to run security cameras. I have multiply wired security cameras plugged into the switch.  I have 1 WiFi security camera connected to my WiFi router  When I configured the switch I set up one vlan1 192.168.0.1.  I have a WiFi router plugged into the switch, the IP address for the router is 192.168.1.1.  If I’m on my pc plugged into the switch I am unable to access a camera or service plugged into my WiFi router such as a camera at 192.168.1.68.  But if I plug pc into WiFi router I can access all my cameras from switch and router.  How can I set the switch to be able to access the camera on the WiFi router.
I still am not clear about your environment. As a next step perhaps you can post the current running config from the switch. And tell us which port on the switch the router is connected to.
Rick
Rick
