09-24-2014 01:09 PM - edited 03-07-2019 08:52 PM
I've got a 3825 setup on my home network and everything is working except for my company provided Avaya VPN phone. Previously I had used the old style CBAC firewall and it worked fine - once I put a rule in to allow inbound ESP traffic. I can't figure out how to do that with the ZBFW. Can anyone help? My current config is below. The VPN phone is located on VLAN 14, in the "Trusted" security zone. Thanks!
Using 4591 out of 491512 bytes
! Last configuration change at 03:18:34 UTC Wed Sep 24 2014
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname phil-r1
boot-start-marker
boot-end-marker
aaa new-model
aaa session-id common
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.100.1 192.168.100.100
ip dhcp excluded-address 192.168.15.1 192.168.15.100
ip dhcp excluded-address 192.168.16.1 192.168.16.100
ip dhcp excluded-address 192.168.14.1 192.168.14.100
ip dhcp pool lwapp-pool
network 192.168.100.0 255.255.255.0
default-router 192.168.100.1
option 43 hex f104.c0a8.6318
ip dhcp pool vlan-15
network 192.168.15.0 255.255.255.0
default-router 192.168.15.1
dns-server 8.8.8.8 8.8.4.4
ip dhcp pool vlan-16
network 192.168.16.0 255.255.255.0
default-router 192.168.16.1
ip dhcp pool vlan-14
network 192.168.14.0 255.255.255.0
default-router 192.168.14.1
ip cef
no ip domain lookup
ip name-server 8.8.8.8
ip name-server 8.8.4.4
redundancy
class-map type inspect match-any Guest_Protocols
match protocol http
match protocol https
match protocol dns
class-map type inspect match-any All_Protocols
match protocol tcp
match protocol udp
match protocol icmp
policy-map type inspect Trusted
class class-default
pass
policy-map type inspect Guest_to_Internet
class type inspect Guest_Protocols
inspect
class class-default
drop
policy-map type inspect Trusted_to_Internet
class type inspect All_Protocols
inspect
class class-default
drop
zone security Trusted
zone security Guest
zone security Internet
zone-pair security Trusted source Trusted destination Trusted
service-policy type inspect Trusted
zone-pair security Trusted->Internet source Trusted destination Internet
service-policy type inspect Trusted_to_Internet
zone-pair security Guest->Internet source Guest destination Internet
service-policy type inspect Guest_to_Internet
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
media-type sfp
negotiation auto
interface GigabitEthernet0/1
description Outside - TWC Roadrunner
ip address dhcp
ip nat outside
ip virtual-reassembly in
zone-member security Internet
duplex auto
speed auto
media-type rj45
interface Integrated-Service-Engine1/0
description Internally connected to NME-AIR-WLC8-K9
ip address 192.168.99.254 255.255.255.0
no keepalive
interface Integrated-Service-Engine1/0.15
encapsulation dot1Q 15
ip address 192.168.15.1 255.255.255.0
ip nat inside
zone-member security Trusted
interface Integrated-Service-Engine1/0.16
encapsulation dot1Q 16
ip address 192.168.16.1 255.255.255.0
ip nat inside
zone-member security Guest
interface GigabitEthernet2/0
description Internally connected to NME-16ES-1G-P
ip address 20.0.0.1 255.255.255.0
load-interval 30
interface GigabitEthernet2/0.14
encapsulation dot1Q 14
ip address 192.168.14.1 255.255.255.0
ip nat inside
interface GigabitEthernet2/0.100
encapsulation dot1Q 100
ip address 192.168.100.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list NAT interface GigabitEthernet0/1 overload
ip access-list standard NAT
permit 192.168.14.0 0.0.0.255
permit 192.168.15.0 0.0.0.255
permit 192.168.16.0 0.0.0.255
control-plane
bridge 15 protocol ieee
bridge 16 protocol ieee
line con 0
password 7
line aux 0
exec-timeout 0 1
no exec
transport output none
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line 130
no exec
transport input all
line vty 0 4
access-class 99 in
privilege level 2
transport input ssh
transport output all
line vty 5 924
access-class 99 in
privilege level 2
transport input ssh
scheduler allocate 20000 1000
