How do I change what IOS to load on C2960?
whiteford
I have just uploaded a new IOS to my C2960 switch, but it still uses the old IOS file, how can I change this?
2960#sh flash:
Directory of flash:/
2 -rwx 5 Mar 1 1993 05:34:25 +00:00 private-config.text
4 -rwx 6370034 Mar 1 1993 05:33:24 +00:00 c2960-lanbase-mz.122-44.SE3.bin
5 -rwx 1957 Mar 1 1993 05:34:25 +00:00 config.text
7 drwx 192 Mar 1 1993 00:10:50 +00:00 c2960-lanbase-mz.122-35.SE5
32514048 bytes total (17807360 bytes free)
CBSO_2960#sh boot
BOOT path-list : flash:c2960-lanbase-mz.122-35.SE5/c2960-lanbase-mz.122-35.SE5.bin
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : yes
Auto upgrade path :
NVRAM/Config file
buffer size: 65536
Collin Clark
In config mode, enter the following command-
boot system flash:c2960-lanbase-mz.122-44.SE3.bin
Then save the config and reload. It should come up with the new IOS.
Hope that helps.
Any reason why I can't add "switchport trunk encapsulation dot1q" to to int gig0/1 port?
I can do "switchport mode trunk" only, is it dot1q only be default or something?
The 2960 only supports 802.1q trunking ie. it does not support ISL trunking. So you don't get the option to set dot1q as it is the only one available.
Jon
