How do I check if a cisco IN-BUILT Module is faulty
Iloveyou
For example if i suspect the LAN port module behind is faulty.
E.g. first 6 ports module is faulty
I believe I can only check the power and fan
Mark Elsen
      - Is this a real current problem, if so include the device model and module part number too (?)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
Depends on the model of the Catalyst switch but "sh post" is one of the most common way.
Iloveyou
It is a Cisco 881.
Sh int br , sh ip int br don't work.
Any idea how to display it briefly?
