Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco Switch 3650 roman Problem Read Only
Moustafa Ali
i have a cisco switch 3650 unable to boot iOS , so it gets directly into the roman mode but can't take any action because it's read only mode
how can i change from read only mode into read/write mode
thanks
balaji.bandi
have you tried ROMMON recovery ?
https://www.cisco.com/c/en/us/support/docs/routers/3600-series-multiservice-platforms/15080-recovery-c3600.html
also suggest to post complete boot log if still an issue.
BB
Leo Laohoo
Post the complete output to the command "set".
switch: set
ABNORMAL_RESET_COUNT=2
ASIC_PCI_RESET=1
BAUD=9600
BOOT=flash:c3750e-universalk9-mz.152-4.e4.bin;
BOOT_LOADER_UPGRADE_DISABLE=1
BSI=0
CFG_MODEL_NUM=WS-C3650-48FS-E
CLEI_CODE_NUMBER=INM2M00ARA
CSR_PCIERST_DISCONNECTED=yes
DC_COPY=yes
ECI_CODE_NUMBER=471210
LICENSE_BOOT_LEVEL=ipservicesk9,all:ngwc;
MAC_ADDR=00:A3:8E:37:98:00
MANUAL_BOOT=no
MODEL_NUM=WS-C3650-48PS
MODEL_REVISION_NUM=Q0
MOTHERBOARD_ASSEMBLY_NUM=73-15901-06
MOTHERBOARD_REVISION_NUM=A0
MOTHERBOARD_SERIAL_NUM=FDO21101HWZ
POE1_ASSEMBLY_NUM=73-16439-02
POE1_REVISION_NUM=A0
POE1_SERIAL_NUM=FDO21101FEK
POE2_ASSEMBLY_NUM=73-16439-02
POE2_REVISION_NUM=A0
POE2_SERIAL_NUM=FDO21101FA3
RANDOM_NUM=408178969
RECOVERY_BUNDLE=sda9:cat3k_caa-recovery.bin
RET_2_RCALTS=1701867143
SWITCH_IGNORE_STARTUP_CFG=1
SWITCH_NUMBER=1
SYSTEM_SERIAL_NUM=FDO2110E29C
TAN_NUM=800-41231-04
TAN_REVISION_NUMBER=A0
TEMPLATE=advanced
TERMLINES=0
VERSION_ID=V05
default_router=192.168.168.1
i=10.1.0.1/255.255.0.0
ip_add=192.168.168.169/255.255.255.0
