How do I configure a switch stack 3850
rfuentes1111
Hi Team,
I have two 3850 switches that I want to do stack can someone please help on the process and command to select the master switch thank you. or how to select the priority.
thank you
7 Replies 7
Just Provision the second swtich
-switch 2 provision ws-c3850-48p
Connect the stack cable , and will join in auto , once the second switch is in the stack set the priority with the highest level
-switch 1 priority 15
-reload
Hi Javier,
Do I just connect my second switch to the one that is on now or do I need to turn it off?
I have one in production and need to add the second switch do I need to shutdown the one that is on Or I can do it when is on and connect the second.
No you don’t need to shutdown the switch 1 just connect the stack cable in
both switches and then turn on the second one, will initiate the second ,
usually is not needed to reboot but I do prefer to do it after integration
to the stack
Just be sure that both has the same iOS version
I agree, but I would do switch 1 priority 15 on master before adding other switches. that way I know sw 1 will be a master in stack
Yes actually I stated that in my first comment :)
