how do I configure my switch port as a PC (virtual client) with DHCP?
Hi, I have created some new vlan- xyz and I want to test my DHCP request works as expected, since there is no end users at this time to test it, i tried to simulate with the below config, but i am not receiving any IP address, i have pasted the debug output also below.. please advice if i am missing something in the config? or need to work with my firewall team to allow any rules? Appreciate your time and help.
Note - I masked the vlan info with xyz in the below config and debug output.
 interface vlan xyz
ip dhcp client client-id ascii ASW12
ip address dhcp
end
Dec 14 14:15:58.762: DHCP: SDiscover attempt # 3 for entry:
Dec 14 14:15:58.762: DHCP Lease server: 0.0.0.0, state: 3 Selecting
Dec 14 14:15:58.762: DHCP transaction id: 1920
Dec 14 14:15:58.762: DHCP: SDiscover placed class-id option: 636973636F706E70
Dec 14 14:15:58.763: DHCP: SDiscover: sending 292 byte length DHCP packet
Dec 14 14:15:58.763: DHCP: SDiscover 292 bytes
Dec 14 14:16:02.761: DHCP: QScan: Timed out Selecting state%Unknown DHCP problem.. No allocation possible
Dec 14 14:16:11.748: DHCP: Waiting for 20 seconds on interface Vlanxyz
Dec 14 14:16:31.749: DHCP: Try 5 to acquire address for Vlan320
Dec 14 14:16:31.755: DHCP: allocate request
Dec 14 14:16:31.755: DHCP: zapping entry in DHC_PURGING state for Vlxyz
Dec 14 14:16:31.755: DHCP: deleting entry 463D4F44 0.0.0.0 from list
Dec 14 14:16:31.756: DHCP Lease server: 0.0.0.0, state: 11 Purging
Dec 14 14:16:31.756: DHCP transaction id: 1920
Dec 14 14:16:31.756: DHCP: new entry. add to queue, interface Vlanxyz
Dec 14 14:16:31.756: DHCP: MAC address specified as 0000.0000.0000 (0 0). Xid is 1921
Hello
It wont work unless you have a routed interface related to the vlan
example: L3/L2 switch interconnect via a trunk
L3 switch
int vlan 10
ip address 10.1.12.1 255.255.255.0
ip dhcp pool lan
network 10.1.12.0/24
default 10.1.12.1
lease 0 8
L2 switch
int vlan 10
no shut
ip address dhcp
Kind Regards
Paul
