How do I configure routes for two WAN connections?
dominet123
This was dumped on me and I am trying to figure it out.
My company has a 3640 with on external ether port that has 32 IPs from our providers. There is a single internal ether port for our internal network.
We are adding another T1 from a different provider. This new line will have 32 IPs also.
Both external ports will use NAT, some with overload, some static.
For reasons we want some specific internal IP's to use a specific external port for access to outside.
I know some about how to configure the router, but this is eluding me.
How do I route a specific internal IP to use a specific external port ?
Example
interface FastEthernet0/1
description inside INSIDE_LAN
ip address 192.168.0.1 255.255.255.0
interface FastEthernet1/0
description OUTSIDE_LAN_1.1.1
ip address 1.1.1.94 55.255.255.224
ip nat outside
! the gateway for this network is 1.1.1.65
interface FastEthernet1/1
description OUTSIDE_LAN_2.2.2
ip address 2.2.2.94 255.255.255.224
ip nat outside
! the gateway for this network is 2.2.2.65
ip nat inside source static 192.168.0.10 2.2.2.89
ip nat inside source static 192.168.0.24 1.1.1.68
ip route 0.0.0.0 0.0.0.0 2.2.2.65
ip route 0.0.0.0 0.0.0.0 1.1.1.65
How do I get 192.168.0.10 to only use FastEthernet1/1 (2.2.2.94) and
How do I get 192.168.0.24 to only use FastEthernet1/0 (1.1.1.94)
Thank you
Jon Marshall
Kevin
When you say  -
do you mean the next-hop ?  If so then PBR will do what you want ie.
access-list 101 permit ip host 192.168.0.10 any
access-list 102 permit ip host 192.168.0.24 any
route-map PBR permit 10
match ip address 101
set ip next-hop 2.2.2.65
route-map PBR permit 20
match ip address 102
set ip next-hop 1.1.1.65
int fa0/1
ip policy route-map PBR
Jon
Jon Marshall
Kevin
When you say  -
int fa0/1
Jon
Ahh
That looks like what I need.
I will give it a try.
Thank you
Collin Clark
Policy Based Routing. Search CCO for info and conf examples.
