How Do I Create a vLan?
LRITTTech870
                   How do I create a VLan and migrate PC1 and PC2 to my new VLAN?
InayathUlla Sharieff
Hi Lionel,
Its pretty easy.  Please find below the procedure to create the vlan and migrate the interface on to that vlan.
Eg:
PC1---F0/1---Switch------------F0/2--PC2
Think PC1 and PC2 are in the same vlan. (Vlan 10)
Switch#vlan 10
Switch(config-vlan)#name vlan10
Switch#end
% Applying VLAN changes may take few minutes.  Please wait
Or you can enter into the vlan database and create the vlan there.
Switch#vlan data
Switch(vlan)#vlan 10
Switch(vlan)#exit
2)
Now go the interface and apply the vlan to it.
Switch# config t
Switch# int f0/1
Switch(config-if)#switchport mode access
Switch(config-if)#switchport access vlan 20
Switch(config-if)#end
Switch# int f0/2
thats it.
Please find link below which explains about vlan configuration:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_9_ea1/configuration/guide/swvlan.html
HTH.
REgards
Inayath
*Plz rate if this helpfull.
LRITTTech870
Thank you!!!!
Thanks for the update Lionel.
Please do remember to rate the content if that helps.
Inayath
