How do I Disable CBC mode ciphers
_Ratha_
Dear all,
I have found on my cisco 2960 with SSL Server Supports Weak Encryption for SSLv3 vulnerabilities.
How do I Disable CBC mode ciphers in order to leave only RC4 ciphers enabled?
I also try the following solution:
http://www.cisco.com/c/en/us/support/docs/security/email-security-appliance/118518-technote-esa-00.html
but cisco switch 2960 do not support the command sslconfig
Thank for your support
2 Accepted Solutions
Steve Fuller
Level 9
Level 9
You can specify which ciphers to use with the ip http secure-ciphersuite command. The context sensitive help i.e., the ?, will tell you which ciphers are supported on the IOS version you have.
Simply include only those ciphers you want to run as options to the command, for example ip http secure-ciphersuite rc4-128-md5 rc4-128-sha.
The switch will run any of the ciphers supported by the IOS version unless you specify which you want to run. You should be able to see which ciphers are supported with the show ip http server secure status command.
c1kv-1#show ip http server secure status
HTTP secure server status: Enabled
HTTP secure server port: 443
HTTP secure server ciphersuite: 3des-ede-cbc-sha des-cbc-sha rc4-128-md5 rc4-128-sha
HTTP secure server client authentication: Disabled
HTTP secure server trustpoint:
HTTP secure server active session modules: ALL
The list cipher suites shown will change when you specify which of those available you would want to use.
c1kv-1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
c1kv-1(config)#ip http secure-ciphersuite ?
  3des-ede-cbc-sha  Encryption type ssl_rsa_with_3des_ede_cbc_sha ciphersuite
  des-cbc-sha       Encryption type ssl_rsa_with_des_cbc_sha ciphersuite
  rc4-128-md5       Encryption type ssl_rsa_with_rc4_128_md5 ciphersuite
  rc4-128-sha       Encryption type ssl_rsa_with_rc4_128_sha ciphersuite
c1kv-1(config)#ip http secure-ciphersuite 3des-ede-cbc-sha
c1kv-1(config)#end
In terms of which to use, take a look at the Recommendations for Cryptographic Algorithms on the Next Generation Encryption page. Cisco show both DES and RC4 as algorithms to avoid. A later IOS version is likely to support additional protocols if those currently supported by your switch are not acceptable to you.
Steve Fuller
Level 9
Level 9
Hi Steve Fuller,
How can I show which ciphers that I am running? and which option is the best one?
Switch(config)#ip http secure-ciphersuite ?
Thank for your suppot
c1kv-1#conf t
c1kv-1(config)#end
Hello Steve,
Understood that by selecting one cipher mode I can eliminate the other cipher mode I do not want. But my question goes further based on the Next Generation. Is Cisco including the new AES-GCM Algorithm on their new IOS/IOS-XE release...? So by upgrading we do include that new option.
