How do I remove an interface from switch-profile Nexus 5548UP
telematique
We have two Nexus 5548UP (sync-peers)
How do I remove an interface from switch-profile?
I have an error
NEXUS-A(config-sync)# switch-profile F1-5548
Switch-Profile started, Profile ID is 1
NEXUS-A(config-sync-sp)# no interface ethernet 1/18
Invalid range at '^' marker.
My version is
kickstart: version 6.0(2)N1(2)
system:  version 6.0(2)N1(2)
Mark Malone
no switch-profile testprof profile-only all -- this deletes whole lot profile and config
if you want the profile to stay but config under it gone
I don't think you can go in an remove just 1 int like that with no statement
Thank you for help
zyx
You can do it in local configuration mode (aka "conf term") issuing command "default interface eth1/18". The interface configuration will be reset to defaults, thus the switch-profile context configuration will be removed as well.
