How do I set up a port for monitoring my network using telnet
UncleJohn44
How do I set up a port for monitoring my network using telnet. I am using a catalyst 4506.
7 Replies 7
ankbhasi
Hi John,
You want to monitor a specific port or specific vlan? Do you have a port which will work as a dstination port where you want to send all monitored traffic?
Do you want to capture traffic on a single switch or from multiple switch?
Are you running CATOS or IOS?
Ankur
I want to capture traffic on a single switch, I believe it is IOS, and I do have a port available. 4/36
Hi John,
Have a look at this link which will help you to configure SPAN.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_1_19/config/span.htm#1020431
Ankur
*pls rate all helpfull post
I am having trouble with these commands, and ask if you could type out the command for me. I having an open port of 4/36, and want to capture traffic using a sniffer for my entire network.
Sorry,
Hi John,
Can you confirm what do you mean by whole network? How many vlans you have in your network? What exactly you want to monitor - the traffic or the stats and utilization etc etc. Cause SPAN will and can capture only traffic coming on or moving out of specific ports or vlans.
Ankur
My network physically located in the same building, and I want to monitor utilization. I have someone mentioning to me that I should be using a sniffer, and that is what I need to set the port up for. I'm not concerned about a VLAN, as I understand that the guy who tried setting up this network never utilized any software to create a VLAN.
John,
Sniffer will provide you with overwhelming information.
I suggest using a network monitoring tool like MRTG or solarwinds for it.
www.solarwinds.net
www.mrtg.com
Narayan
