How do I share connection between 2 dhcp pools?
kweightman
Hi All
we currently run our LAN on a 192.168.2.x  255.255.255.0 network. We separated our wireless access points to run off 192.168.3.x network. The WAPs give out dhcp fine, but gets no internet or internal connection.
How do we make the .3.x wlan connect to the .2.x lan and get internet and connect to internal resources?
Im new to cisco so please be patient!
Thanks!
10 Replies 10
John Blakley
The wireless clients should be on a separate vlan. The data clients are probably on your native vlan. (Maybe you could post the config.) If the data clients are getting to the internet, but the wireless clients aren't, it's probably got something to do with either routing or nat.
Is dhcp on a router/switch or a server?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
the WAN goes into a 891 switch (config is below) which connects to a 3000 switch with both wired and wireless clients. The wireless is on a different vlan(we named vlan 10), and gets dhcp fine, so i think problem is we need to connect the two vlans somehow?
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication ppp default local
aaa session-id common
crypto pki trustpoint TP-self-signed-298659689
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-298659689
revocation-check none
rsakeypair TP-self-signed-298659689
ip source-route
ip dhcp excluded-address 192.168.2.1 192.168.2.10
ip dhcp excluded-address 192.168.2.200 192.168.2.254
ip dhcp excluded-address 192.168.2.10
ip dhcp excluded-address 192.168.2.254
ip dhcp pool 0
   import all
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   dns-server 192.168.2.1 192.168.2.1
   lease infinite
ip dhcp pool 10
   network 192.168.3.0 255.255.255.0
interface Loopback0
no ip address
interface FastEthernet0
switchport mode trunk
duplex full
speed 100
interface FastEthernet1
shutdown
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface FastEthernet4
shutdown
interface FastEthernet5
shutdown
interface FastEthernet6
shutdown
interface FastEthernet7
shutdown
interface FastEthernet8
description $ES_WAN$$FW_OUTSIDE$
bandwidth 1800
bandwidth receive 13000
ip address 192.168.0.254 255.255.255.0
ip access-group 103 in
ip nat enable
ip tcp adjust-mss 1452
duplex full
speed 100
priority-group 5
crypto map ipsec-rackspace
interface Virtual-Template1
ip unnumbered Vlan1
ip access-group 104 in
ip access-group 104 out
ip nat enable
peer default ip address pool defaultpool
ppp encrypt mppe auto required
ppp authentication ms-chap ms-chap-v2
interface GigabitEthernet0
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 1$
ip address 192.168.2.1 255.255.255.0
ip access-group 102 in
ip access-group 102 out
ip flow ingress
ip nat enable
interface Vlan10
description $WI-FI VLAN 1$
ip address 192.168.3.1 255.255.255.0
ip access-group 123 in
ip access-group 123 out
ip flow ingress
ip nat inside
ip nat enable
ip virtual-reassembly
interface Async1
no ip address
encapsulation slip
router eigrp 1
network 192.168.2.0
network 192.168.3.0
ip local pool defaultpool 10.0.2.1 10.0.2.255
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
Drew Browning
Do you have the SVI created on core for the inter-vlan routing?
no idea, the config is above?
Hi Kyle,
ip dhcp pool 10
the default-gateway for the clients in the 192.168.3.0/24 network should be 192.168.3.1
Rolf
ok bwhat about DNS?
if i change the GW to .3.1 will that be able to connect to internet then?
thanks for this, not very experienced!
With a new DHCP lease, a wireless client now should be able to reach it's default gateway (ping 192.168.3.1).
I'd expect that that 192.168.2.1 is be reachalbe too, so DNS should work as well.
If the wireless client can ping 192.168.2.1, you can test DNS with "nslookup www.cisco.com".
would 192.168.2.1 (the 891)  be reachable from a .3.1 client though?
If not, what should i check for?
Perhaps we should have a look at the access-lists.
Could you post the outputs of
  • show access-list 102
  • show access-list 123
Extended IP access list 102
    10 permit tcp any any eq www log (4655378 matches)
    20 permit tcp any eq www any log (5026056 matches)
    30 permit tcp any any eq domain log
    40 permit tcp any eq domain any log
    50 permit ip any any (3654644 matches)
ciscorouter#show access-list 123
Extended IP access list 123
    10 permit tcp any any eq www (167 matches)
    20 permit tcp any any eq domain
    30 permit udp any any eq domain (49 matches)
    40 permit ip any host 192.168.2.205
    50 permit ip any host 192.168.2.250 (35 matches)
    60 permit ip any host 192.168.2.241
    70 permit ip any host 192.168.2.204 (14 matches)
    80 permit ip any host 192.168.2.248 (8 matches)
    90 permit ip any host 192.168.2.228
    100 permit ip any host 192.168.2.229
    110 permit ip any host 192.168.2.247 (9 matches)
    120 permit ip any host 192.168.2.251
    130 permit ip any host 192.168.2.252
    140 permit ip any host 192.168.2.202
    150 permit ip any any (2111 matches)
Edit: i should also say that when connecting to wirelss, it assigns 192.168.3.x addresses fine, but cant connect to internet or network resources. I presume because they are all on 192.168.2.x network?
thanks
