How i can calculate the backplane speed & throughput of cisco 48 1G 2960S switch?
sachit.anand
satya mothukuri
As per my knowledge ......
LAN Base (-L) Models
LAN Lite (-S) Models
Forwarding bandwidth
88Gbps
50 Gbps
Switching bandwidth*
176 Gbps
100 Gbps
Satya.M
(Please Rate if Helps)
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Calculate?  Calculate for wirespeed/line-rate?  If the latter, take all the port bandwidths, and assuming they are duplex, double for necessary fabric bandwidth.  I.e. 48 gig ports would need a 96 Gbps fabric.  Take all your port bandwidths, and allow 1.448 Mpps per gig (for minimum size Ethernet packets), i.e. 48 gig ports would need 69.5 Mpps.  Once you have required fabric bandwidth and PPS, you can compare to vendor's specs.
Jeff Van Houten
Level 5
Level 5
The stack cable/ring on 2960s switches has a maximum capacity of 20 Gbps.
