How I can change size of Ethernet frame ???
ksn77
How I can change size of Ethernet frame at cisco 871 ?
I have channel (point to point) from my ISP.
Topology of this channel is "Bridge".
This schema doesn't work :
cisco871 <- ADSL modem -> ISP <-- ADSL modem --> cisco 871
192.168.11.1 192.168.11.2
But this schema work propertly:
cisco2611xm <- ADSL modem -> ISP <-- ADSL modem --> winodws2003(routing on)<--> cisco 871
My ISP said me: "Your cisco871 have outgoing Ethernet-frame more 1508 and ISP reject its. "
I don't understand why cisco2611xm work propertly so cisco871 doesn't when i use ISP's "Bridge".
I'm can't change MTU at FastEthernet inetface:
cisco871
pervomay(config)#interface fastEthernet 4
pervomay(config-if)#mtu
pervomay(config-if)#mtu ?
<64-17940> MTU size in bytes
pervomay(config-if)#mtu 1450
% Interface FastEthernet4 does not support user settable mtu.
c.lemaire
You should try with the 'system mtu xxx' command in global config or with the 'ip tcp adjust-mss xxx' command in interface config.
As I understand in this device where is no ability to execute command 'system mtu xxx':
pervomay#sys?
systat
pervomay#
I tryed ip 'tcp adjust-mss xxx' and 'ip mtu xxxx' but no result was given.
scottmac
Level 10
Level 10
Try "ip mtu xxxx" frmo the interface config prompt.
Also, relatively few frames are actually that large. For most networks, the majority of traffic is in the 128-512 byte range.
If the ISP is seeing frames larger than 1508, then you may also have some kind of tagging / VLAN active or there's a proxy tag ... some other information is being added to the ethernet frame.
Good Luck
Scott
My understanding is that on the 871 the FE ports is a switch port not a router port, so you won't be able to change the MTU size on that port. You will be able to change on the router port, i.e any port you can assign IP address to..
